Gtir Motorsport club » Tech room » Help and Advice » Wheel Spacers
Wheel Spacers
1Wheel Spacers Empty Wheel Spacers on 31st August 2016, 11:38 am
Mark Ager
Hi Anyone recommend where I can get a set of 20mm wheel spacers? I want the kind which have secondary studs.
I have a smaller set of wheels i'm looking to use and they foul the calliper.
cheers
2Wheel Spacers Empty Re: Wheel Spacers on 31st August 2016, 8:15 pm
Make sure they are hub centric spacers Smile
3Wheel Spacers Empty Re: Wheel Spacers on 31st August 2016, 8:54 pm
http://www.superforma.co.uk/wheel-spacers/bolt-on-spacer-kits/4x100-wheel-spacer-pair-cb-59-1-m12x1-25-nut.html?___SID=U
4Wheel Spacers Empty Re: Wheel Spacers on 31st August 2016, 8:56 pm
Try above link dont think its quite right vehicle selected but should get you in the ball park of what you want ...
5Wheel Spacers Empty Re: Wheel Spacers on 1st September 2016, 10:34 am
Didnt someone on here get some made up?
6Wheel Spacers Empty Re: Wheel Spacers on 1st September 2016, 10:52 am
7Wheel Spacers Empty Re: Wheel Spacers on 18th September 2016, 8:57 am
Mark Ager
Anyone know the hub size? I don't have a accurate measuring tool it looks like 55-58mm? somewhere in there
8Wheel Spacers Empty Re: Wheel Spacers on 18th September 2016, 9:01 am
Mark Ager
Just found on line says 59.10? Is that right?
9Wheel Spacers Empty Re: Wheel Spacers on 18th September 2016, 9:26 am
^ that's right, you can go bigger & use spigot ring to correct it, lot of wheels have a ring that can be swapped to suite (don't use the crappy plastic ones if can help it) or wheel can be machined to suite ...
10Wheel Spacers Empty Re: Wheel Spacers on 19th September 2016, 12:34 am
This company make them
http://www.tcsportline.com/
Contact them with the size you want eg 4x100 25mm CB 59.1 hub centric and if not in stock they will probably make them.
I bought 15mm about 6 years ago, fit was perfect.
But a warning. they cannot be used on most multi-stud wheels as they require a blank hole (ie. like stock wheels or only single 4x100 wheels) where the original studs poke through.
