Gtir Motorsport club » General Discusion » Gtir related Discussion » starter motor
starter motor
1starter motor Empty starter motor on 11th September 2016, 11:54 am
My replacement starter motor stipped working yesterday Sad
Luckily i had bought new bushes to recon the one i had taken off. So i stripped it back down and installed them.
Then swapped them over and the car started on point Smile
Just taken the replacement starter motor apart and the same issue is there. 2 of the 4 bushes have worn away to the point that they no longer touch the internal spline.
Nice easy cheap repair for anyone else that has this issue!
http://www.ebay.ie/itm/161070431251
I took all the magnets out and cleaned off all the carbon off them and inside the casing. Then swapped the old part for the new part and bingo its a reconed starter motor.
2starter motor Empty Re: starter motor on 11th September 2016, 4:50 pm
Hey Stu,
Thats a top tip mate, ive just bought those magnets to keep ready,
For the sake of 15 notes its a no brainer,
Very Happy
3starter motor Empty Re: starter motor on 11th September 2016, 5:08 pm
Hi Neil.
For the price mate its worth having some at hand.
4starter motor Empty Re: starter motor on 11th September 2016, 5:10 pm
These are what came out.
You can see how much material has worn away over 25 years.
starter motor 20160911_180839_zpsskqfnzf4
5starter motor Empty Re: starter motor on 12th September 2016, 1:10 am
Nice mate, might pick one up myself, not expensive to do.
6starter motor Empty Re: starter motor on 12th September 2016, 11:08 am
Is it an easy job to do Stu?
Question
7starter motor Empty Re: starter motor on 12th September 2016, 12:10 pm
Im sure if you can build a gearbox to such precision a starter motor will be a walk in the park lol
8starter motor Empty Re: starter motor on 12th September 2016, 4:29 pm
not with starter motors. Its all electrickery and im useless at it.
Bob tried to explain how my AVC thing worked and all i could do was nod and smile.
wtf!
9starter motor Empty Re: starter motor on 12th September 2016, 4:40 pm
@Cosmic73 wrote:Is it an easy job to do Stu?
Question
Two 8mm bolts on the end. Undo and pull them all the way out. They are about 8 inches long.
Then the cap will come off with a small tap to the edges.
When its off theres just 2 small screws holding the bushes plate on. Undo those and remove and also the nut on the outside holding the wire to the terminal.
Thats all it is to replace the bushes Neil.
To clean the magnets. Remove the spline. Its free so just pull it out.
The magnets have spring plates holding them in place. Thin nose plies and prise them out and the magnets will come out.
Its all straight forward mate. When you start taking it apart you will see how simple and straight forward it is Wink
10starter motor Empty Re: starter motor on 13th September 2016, 10:19 am
These 2 diagrams will give you some idea as well.
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/engine_electrical/starter_motor/illustration_1/
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/engine_electrical/starter_motor/illustration_2/
11starter motor Empty Re: starter motor on 13th September 2016, 3:24 pm
@splmum wrote:These 2 diagrams will give you some idea as well.
The second link is our one.
Its mine atleast..
12starter motor Empty Re: starter motor on 13th September 2016, 6:02 pm
Thought i'd go grab my old one out from the garage but just pulled it apart and then remembered why it was buggered. Armature commutator bar is burnt out due to worn brushes fusing to it so only fit for the bin. I'll refurb my new one though Smile
