Gtir Motorsport club » Tech room » Help and Advice » Big ends
Big ends
1Big ends Empty Big ends on 11th September 2016, 5:23 pm
Gti-r dannyboy
Big ends Image10
Big ends Image11
Big ends Image12
Big ends Image10
Big ends Image11
Big ends Image12
2Big ends Empty Re: Big ends on 11th September 2016, 5:25 pm
Gti-r dannyboy
Is this a part of the big end shells?
3Big ends Empty Re: Big ends on 11th September 2016, 5:52 pm
Where did you find it in the sump ???
4Big ends Empty Re: Big ends on 11th September 2016, 6:01 pm
Gti-r dannyboy
Yeah
5Big ends Empty Re: Big ends on 11th September 2016, 7:06 pm
You found those in your sump??? It must have been rattling it's tits off?!?!
6Big ends Empty Re: Big ends on 11th September 2016, 7:44 pm
Gti-r dannyboy
All the knocking started and killed the engine within half amile!!!
7Big ends Empty Re: Big ends on 11th September 2016, 7:45 pm
Whats the diameter?
Best case youve spun a rod shell,
Worst case you've spun a big end shell.
If its a big end shell, i reckon damage like that will mean a new block, and like Pete said, would sound like an 80's diesel.
8Big ends Empty Re: Big ends on 11th September 2016, 8:03 pm
If it's the big end the crank will be scrap
9Big ends Empty Re: Big ends on 11th September 2016, 9:04 pm
Only 1 oil hole... me think big end
10Big ends Empty Re: Big ends on 12th September 2016, 4:34 pm
Gti-r dannyboy
Luckily this is a spare engine, i will have to strip it down over winter to investigate a little more.
11Big ends Empty Re: Big ends on 12th September 2016, 4:47 pm
Assume it been left in sump then after some investigation/tinkering as if found that in sump you would soon see where came from as a rod would be hanging off :-D
spun bearing in rod means rod is scrap & so is crank if journals beyond a regrind
Spun mains means new block, you can dick about with caps & line boring but never worth hassle if can get a decent block easily . Needs proper good looking at as had big failure possibly .
12Big ends Empty Re: Big ends on 12th September 2016, 4:49 pm
Fingers crossed the block and crank can be salvaged, Smile
13Big ends Empty Re: Big ends on 12th September 2016, 5:04 pm
Proper engine machinist can save a lot, line honing journals is skilled work & not many could it it to high enough standard want bother, cranks can be ground .25 & can go .50 but hard get bearings .50
with cost of machining, crank hardening treatment and ordering custom oversize/undersize bearings it way better pick up more junk 54C's and salvage what good .
Good spares getting harder come across though so finding proper engine machinist can be useful ...
