Gtir Motorsport club » active members adverts » Parts Wanted » Working central locking and window control unit
1Working central locking and window control unit Empty Working central locking and window control unit on 16th September 2016, 5:24 pm
DRC
DRC
Since I have had the r the central locking has never worked correctly. I have had the alarm replaced today and the fitter mentioned that he thinks the relay is the problem as it will not lock or unlock the doors. So I would like to start by changing the window lock control unit for a working one. Please let me know what you have.
Thanks
2Working central locking and window control unit Empty Re: Working central locking and window control unit on 16th September 2016, 9:15 pm
With the alarm do you not have seperate solenoids on the locking mechanism? Mine got really stiff and I had to put some oil/grease on the contacts. Have no idea about your setup tho so just an idea!
3Working central locking and window control unit Empty Re: Working central locking and window control unit on 18th September 2016, 9:05 am
I think all the door locking and window winding are controlled by the same box in the drivers door arm rest. If anything on  that doesn't work then swapping the whole lot is about the only answer - and I think working ones are getting hard to find.... (and expensive)  I've got several where the windows don't work but the locking is OK so you are welcome to one or two of those so you may be able to swap bits around - but they aren't simple switches...   Shocked  Two relays in here but unlikely to be one of those.
Working central locking and window control unit Windfow%20switch_zpsrulqv624
Most alarms I've seen just have one solenoid added to operate the drivers door and this then activates the central locking.
4Working central locking and window control unit Empty Re: Working central locking and window control unit on 19th September 2016, 4:09 am
Whytie
Whytie
I've got a few of these if your still looking
5Working central locking and window control unit Empty Re: Working central locking and window control unit on 19th September 2016, 8:19 am
When i removed the Clifford alarm from my R i found the windows and locking stopped working,
Upon removing the door panel i noticed the power feed wire had been snipped and intercepted by the alarm,
I just joined the right coloured wires back together and it all worked again, Smile Smile
