Gtir Motorsport club » Tech room » Help and Advice » hks evc-s faulty?
hks evc-s faulty?
1 hks evc-s faulty? on 29th September 2016, 8:03 pm
Has anyone had problems with one over reading? It makes out that i'm boosting 30psi when my gauge is peaking 15psi.
I have the boost sensor going into the rear inlet chamber then t-pieced to the fuel pressure regulator and i also have the boost gauge in that t-piece further down. I'm wondering if i should have the boost gauge separate from the boost controller.
2 Re: hks evc-s faulty? on 29th September 2016, 8:18 pm
I would not t to much inline with pressure Reg as leaks anywhere ain't good and will effect fueling but direct in that line will cause worse fueling issues and faster Det
3 Re: hks evc-s faulty? on 29th September 2016, 9:13 pm
Instructions say to T into the fpr though. Where do you have yours spliced into?
4 Re: hks evc-s faulty? on 30th September 2016, 7:44 am
I used to run my Blitz boost controller off one of the vacuum nipples behind/underneath the plenum and seemed to work ok. Granted I'd removed the carbon canister and re-plumbed stuff so there was a spare nipple there (oo er!).
I wouldn't tee anything into the FPR line though, just in case Smile
5 Re: hks evc-s faulty? on 30th September 2016, 12:56 pm
Why do they choose to use the fpr's? Odd.
I have no carbon canister either Smile will have to change some vacuums when i pull the engine out sunday.
6 Re: hks evc-s faulty? on 30th September 2016, 1:03 pm
Is there anything wrong with using the vacuum near the reg that went to the small pipe on top of the carbon canister? Could use that for the boost gauge or the one on the side of the inlet? Thanks
7 Re: hks evc-s faulty? on 30th September 2016, 1:10 pm
You could always tee into the standard boost sensor line on the passenger side inner wing if in doubt.
8 Re: hks evc-s faulty? on 30th September 2016, 1:38 pm
Gone now because i have boost controller. Talking of fuel issues i do get hesitation when loading it up in 1st of second sometimes and have to nail it and the it clears buy comes back. Could be maf related but will sort the vacuums out and try.
9 Re: hks evc-s faulty? on 30th September 2016, 2:22 pm
mine used to do that too. you'd hit a flat spot/misfire that you could drive through then it would seem to pick up and go ok. Turned out the fuel pump wasn't up to the job and the injectors were choked so it was leaning out Sad
10 Re: hks evc-s faulty? on 30th September 2016, 2:37 pm
Had it on my old pump and on my genuine walbro i have now so got to be something else. Will sort the vacuums out and go from there and then maybe try a maf if it's the same
