Gtir Motorsport club » Tech room » Help and Advice » Clutch??!
Clutch??!
1 Clutch??! on 9th October 2016, 5:15 pm
pulsar23
Thinking ahead about doing my clutch and was wondering what to get?! Running around 300bhp?
Also probably going to take engine out, so what would you recommend to do while the engine is out?
Cheers in advance
2 Re: Clutch??! on 9th October 2016, 5:44 pm
Helix organic clutches are good! I had one in mine, no slip, and easy on the clutch pedal
3 Re: Clutch??! on 9th October 2016, 6:36 pm
Same helix organic but order asap as they take ages to deliver I had to wait 16 weeks
4 Re: Clutch??! on 9th October 2016, 8:13 pm
I don't rate them like I used to no slipping fair enough but they don't last long at 300 bhp or mine did not looks very worn for the time it's been in. Plus very expensive. Trying cc this time mr b and few others had good reviews so
5 Re: Clutch??! on 9th October 2016, 8:20 pm
Check wiring. Renew hoses etc. You done the ones on rear of block ? Small clips or cable ties on vac lines at rear of plenum. Mounts condition ?
6 Re: Clutch??! on 9th October 2016, 8:28 pm
Also check condition of your clutch fork. I shall be strengthening mine on my rebuild
7 Re: Clutch??! on 9th October 2016, 8:31 pm
pulsar23
Ok I will know more once it's out. Who are cc? Thanks chaps
8 Re: Clutch??! on 9th October 2016, 8:36 pm
I believe it stands for Competition Clutch
9 Re: Clutch??! on 9th October 2016, 8:44 pm
It dose. Don't get me wrong helix was good but just looks very worn and what's people paying for them these days mine was not cheap
10 Re: Clutch??! on 9th October 2016, 8:48 pm
pulsar23
Looked at comp clutch and would I go for stage 2 or 3?
11 Re: Clutch??! on 9th October 2016, 9:06 pm
I think you really have to look at where you want to be at .... 330bhp will it stop there and be happy with that in the future .... like johnny wisely said other jobs are really important like hoses etc as you dont want to have to rip the lump back out for something silly .... modified clutch fork is a must for heavier clutches .... and pedal support bracket with the extra strain of heavier clutch ....
12 Re: Clutch??! on 10th October 2016, 6:42 am
I'd check all your rubber mounts to see if they have perished, check turbo for excessive play, and I'd check over the engine/gearbox for any leaks...much easier repairing bits and bobs whilst the whole lot is out Smile
13 Re: Clutch??! on 10th October 2016, 7:18 am
I started my clutch change 2 years ago .. but they job became so much more .
I went for a CC clutch
14 Re: Clutch??! on 10th October 2016, 8:15 am
pulsar23
Fancy doing it Rob?
15 Re: Clutch??! on 10th October 2016, 9:15 pm
Partypete's your man for the job what he doesnt know about gearbox removal isnt worth knowing lol ...
16 Re: Clutch??! on 11th October 2016, 3:22 pm
stage 3 CC, be sure skim or fit new flywheel & a new oem release bearing (blueprint do them cheap enough)
If engine out do clutch master cylinder (not expensive) as if not been done already it going be a soon needed job and way harder with engine in .
17 Re: Clutch??! on 11th October 2016, 4:40 pm
Any brake lines that need renewed all the way back to the abs is worth thinking about
