Gtir Motorsport club » Tech room » Help and Advice » Loom
Loom
1 Loom on 31st October 2016, 8:27 pm
Someone fitted a Apexi Safc2 to my Pulsar many years ago and used scotch locks. Someone stole the safc and tried pulling the loom out too so its a bit of a mess. whats the best thing I can do?
1) Get a diagram for the loom and remove all scotch locks and try to re solder
2) can I replace that part of the loom?
2 Re: Loom on 31st October 2016, 8:34 pm
What you trying to achieve mate the safc totally gone ? And loom tidy
3 Re: Loom on 31st October 2016, 8:51 pm
Well im not sure the scotch locks are the best thing to do? as they may mess up the signal. tbh it was a bit fucked and the car wouldnt run at all so I messed about until it would run but wasnt using a diagram so wanted to try and get it all back to how it should be. At the moment I have a stock t28 and want to keep it that way so doubt there is a need for a half patched in safc loom. i do have a safc2 but the cabling isnt all plumbed in right.
4 Re: Loom on 31st October 2016, 8:52 pm
@johnny gtir wrote:What you trying to achieve mate the safc totally gone ? And loom tidy
So basically yes to your question lol
5 Re: Loom on 2nd November 2016, 7:10 pm
I did have a copy but could anyone point me to a ecu diagram with wire colours please and outputs?
6 Re: Loom on 2nd November 2016, 8:11 pm
What's your plans? . Decent scotch locks can be as good as solder joints as solder can cause dry solder joins( more so circuit boards) if done the heat travels along way up a cable very fast so be careful and the solder can increase resistance. Heat shrink any bare cable or joint once tested
7 Re: Loom on 2nd November 2016, 8:26 pm
Well the wiring for the safc is half in half out so just want to tidy it all up really and any damage I can solder and re wrap.
8 Re: Loom on 2nd November 2016, 9:27 pm
Pin #
Name
Function
Signal Type
2.
Tachometer Signal
Engine Speed Sensor Signal
Speed
4.
Main Relay (Electronic Concentrated Control System)
12V Switched
Power
6.
Power Ground (Electronic Concentrated Control System)
Chassis Ground
Ground
13.
Chassis Ground
Ground
16.
Mass Air Flow Sensor
Mass Air Flow Sensor Signal
Analog
17.
Mass Air Flow Sensor Ground
Chassis Ground
Ground
18.
Engine Coolant Temperature Sensor
Engine Coolant Temperature Sensor Signal
Analog
19.
O2 Sensor Signal
Oxygen Sensor Signal
Analog
20.
Throttle Position Sensor
Throttle Position Sensor Signal
Analog
21.
Sensor Ground
Chassis Ground
Ground
26.
Air Temperature Sensor
Air Temperature Sensor Signal
Analog
27.
Knock Sensor
Knock Sensor Signal
Knock, Audio
29.
Sensor Ground
Chassis Ground
Ground
32.
Vehicle Speed Sensor
Vehicle Speed Sensor Signal
Speed
36.
Ignition Switch
12V Switched
Power
39.
Chassis Ground
Ground
46.
Power Supply (Aux)
12V Permanent
Power
47.
Power Supply (Engine Control Module)
12 Switched
Power
48.
Chassis Ground
Ground
101.
Injector # 1
Speed
103.
Injector # 3
Speed
107.
Chassis Ground
Ground
108.
Chassis Ground
Ground
109.
Power Supply (Aux)
12V Permanent
Power
110.
Injector # 2
Speed
112.
Injector # 4
Speed
116.
Chassis Ground
Ground
