Gtir Motorsport club » Tech room » Help and Advice » CRB or something else?
51 Re: CRB or something else? on 8th February 2017, 9:22 am
Well its been a while now but thought I'd update.
I bought a gearbox off Whytie to replace my one and got it fitted in December.
Just as well I had another one to hand as, quite literally as I was pulling into the garage I couldn't get the stick over to 1st/2nd gates, they had simply gone!
Anyway, I got the box swapped over and as soon I drove it away I knew something was wrong with the gear change. Needless to say I was starting to panic a little! I pulled the gaitor off the stick and wiggled the stick around to find the whole gear change assembly was moving around. A trip to the garage to have a look confirmed the front bush on the gear linkage stabiliser was borked, looking like the inner bush had gone it was that bad.
Got a replacement bush ordered from Amazon and had that fitted last week and it now feels like you're loading a high powered rifle, its that precise.
As an aside I took the old box home in case I ever needed to get it rebuilt in future. I'm guessing that having around 3mm movement on the input shaft isn't normal? Shocked
I'd like to thank everyone for their advice along with Whytie (and has pal Patrick for delivering the box) for supplying the replacement box.
its been a long road but I finally got there!  Very Happy
cheers for now,
mike
52 Re: CRB or something else? on 8th February 2017, 9:30 am
glad it's all fixed. It's amazing the difference new bushes make to shifting.
I had an XR3i and changing gear was like rummaging about inside a knackered old tool box,
Changed the bush and like you say, it was like loading a Winchester rifle.
Very Happy
3mm of input shaft travel is def not good  Shocked
53 Re: CRB or something else? on 8th February 2017, 10:02 am
Glad you got sorted with another box. Good to see there's plenty of people in the community to help you out mate Smile
54 Re: CRB or something else? on 8th February 2017, 11:02 am
Pleased it's sorted remind us was that all so the cars good to go ?
55 Re: CRB or something else? on 8th February 2017, 11:17 am
yep, pretty much good to go other than wear n tear type rubbish...just got a delimiter chip & 3" turbo elbow to fit, remove Y bracket, carbon canister, tidy boost lines etc etc, lol
56 Re: CRB or something else? on 8th February 2017, 8:17 pm
Also had a few dealings with whytie on parts and met him a couple times nice guy good genuine parts as described so rep given to him. That's what this forums all about
