Gtir Motorsport club » Gallery » Members gti-r's » My GTI-R
My GTI-R
Go to page : 1, 2, 3  Next
1 My GTI-R on 13th November 2016, 10:26 pm
danno
I haven't worked out how to upload pics yet on my phone (windows phone is crap) but the spec of the car is as follows. I'm no expert, just going on what info I've found on the forums.
Its a black import with 74000 miles on the clock
Turbo back exhaust with the cat still in (think its a mongoose)
Forge recirculating dump valve
K&N air filter
Silicone HT leads
GAB front shocks with what look like tein lowering springs as they're green
Unknown rear shocks and lowering springs
Poly arb mount bushes
Nismo foot rest
Knee pads left and right
Rear strut brace with a hoop over the back seats
No front strut brace
Standard alloys
That's it as far as I can tell but it came with a few aftermarket parts not fitted.
Pace front mount intercooler kit
Poly engine and box mounts
Urban cammo, samco silicone engine hose kit
Its off the road tho as it needs a few bits doing, mainly the gearbox, it stuck in reverse so I've got that out this weekend and ill have a look at it in work.
I take my hat off to those who can get the box out without pulling the whole lot out as I did, I got cheesed off and was spending more time thinking and less time doing and logic told me just to take the engine and box out
2 Re: My GTI-R on 13th November 2016, 10:34 pm
Use photobucket to upload pics to photobucket then copy link ... you want the link that is img .... then paste it on here in the box you write in thats it ... hope this helps ... any problems just let me know .
3 Re: My GTI-R on 13th November 2016, 11:57 pm
danno
Ah, forgot about the old photobucket, cheers dude.
4 Re: My GTI-R on 14th November 2016, 12:01 am
danno
I cant seem to get it to work, I've done it before on a different forum, but when I click send it just loads the post reply page back up.
5 Re: My GTI-R on 14th November 2016, 6:51 am
Car sounds a good base with a few optional extras. Depending on what's to do sometimes it's easier to drop the whole lot depending on what's to do. Check everything especially rear of engine while it's out. Water pipes etc
6 Re: My GTI-R on 14th November 2016, 7:45 am
I use https://postimage.org just copy the "Hotlink for forums" link into the reply section and should work
7 Re: My GTI-R on 14th November 2016, 11:42 am
danno
Thanks guys, ill try that other site and see what happens.
Yes it was definitely easier, and I've got a four post ramp too so it was almost smooth sailing untill I realised the ramps weren't far enough apart and couldn't get the engine and box through "doh" but I got there in the end.
I'll definitely give the engine a once over, I don't really want to take it all out again not long after its gone back in ha ha.
Might even fit the hose kit.
8 Re: My GTI-R on 14th November 2016, 1:16 pm
I would 100% do rear hoses and water pump as if originals they are close to end (oem hoses best option and not much more than silicone), would do clutch master too as adl do them and not expensive.
Keeps reliability and saves a lot of ball ache ...
9 Re: My GTI-R on 14th November 2016, 2:10 pm
danno
Yer well if they don't look perished ill leave them to be honest, I may be eating my words at some point but I believe in "if its not broke don't fix it", though I will do the water pump if it hasn't already been done. The owners previous to the guy I bought it off spared no expense when it came to servicing it so its in pretty good nick.
I fixed the problem anyway, the selector had jumped out of position as I flicked from first to reverse too quick while moving it back and forth. And also this could of been rectified in situ, as I pulled the reverse light switch out to see why the box wouldn't split all the way, the selector was staring me in the face, so I pulled the whole lot out for nothing, I could of cried. But its all a learning curve and now have access to hard to get to parts such as the rack which is leaking so ill reseal that before the lot goes back in.
10 Re: My GTI-R on 14th November 2016, 7:56 pm
+1 on rear hoses... At some point one after another burst on mine cos of this had to do head gasket and trust me removing Intake manifold just to change oil cooler hose suicide fuming
Put it this way I refused to put mates car back together because he didn't want to change rear hoses lol!
11 Re: My GTI-R on 14th November 2016, 8:59 pm
Shit, no body warned me about this when i did my rebuild.
Bollocks Shocked
12 Re: My GTI-R on 14th November 2016, 9:05 pm
I will do yours if they go and while you watch you can build my box lol
13 Re: My GTI-R on 14th November 2016, 10:02 pm
send it down and ill take a look  Smile
14 Re: My GTI-R on 15th November 2016, 10:17 pm
danno
Ok, maybe I will change them if that's the case, it wont hurt to do it, less so than when its put back in.
So I've been digging through the folder of receipts and found its got a RPS max street clutch kit fitted back in 2005, they any good? It feels heavy but was working fine so I'm assuming that's because its uprated.
There's also a spot lamp grill with it to but no lamps. Are there specific lamps that fit or can I get off the shelf universal ones that fit?
15 Re: My GTI-R on 25th January 2017, 10:52 pm
danno
16 Re: My GTI-R on 25th January 2017, 10:53 pm
danno
17 Re: My GTI-R on 25th January 2017, 10:54 pm
danno
18 Re: My GTI-R on 25th January 2017, 10:55 pm
danno
19 Re: My GTI-R on 25th January 2017, 11:04 pm
danno
Got a new phone now so uploading pics is easy haha.
Sooo, ive fixed my window problem, twas the drivers door switches not working and was pointed to some on ebay for a four door and they worked
20 Re: My GTI-R on 25th January 2017, 11:19 pm
Glad to hear it was an easy repair in the end .. was the gaffer tape there because the window never shut ???
21 Re: My GTI-R on 25th January 2017, 11:37 pm
You have some nice options there Smile
22 Re: My GTI-R on 26th January 2017, 4:06 am
Looks great, as Stu said some rare options there Smile
23 Re: My GTI-R on 26th January 2017, 7:23 am
danno
Thanks, yeah the tape is on both windows and the car had been parked up for 18 months outside so the tape had gone to like powder but the glue is welded on
24 Re: My GTI-R on 26th January 2017, 8:34 am
@danno wrote:Thanks, yeah the tape is on both windows and the car had been parked up for 18 months outside so the tape had gone to like powder but the glue is welded on
Try using some tfr or lemon oil to remove the glue.
Only tet patch the lemon oil in a small patch first tho as it is strong and may melt the paint.
We used to fill plastic cups with the stuff when I first started work and the cup would melt over an hour or so.
25 Re: My GTI-R on 29th January 2017, 11:35 am
danno
Sounds like good stuff then, ill have a look online for some as ive never heard of lemon oil.
It also turns out that i have a complete fog lamp set up, it was all in a carrier bag that i thought was just full of wires lol, but its in bits and the brackets are bent out of shape so they'll need sorting out.
