Gtir Motorsport club » Tech room » Help and Advice » Boot can't open
Boot can't open
1Boot can't open Empty Boot can't open on 10th December 2016, 1:13 pm
Any other way to get this open?
Bonnet release hinge not working, key not working to open the boot.
Boot can't open Image12
Boot can't open Image11
2Boot can't open Empty Re: Boot can't open on 10th December 2016, 1:44 pm
Climb in the back through the rear seats, you can open the boot with the small latch direct on the latch
3Boot can't open Empty Re: Boot can't open on 10th December 2016, 1:45 pm
The cable might have broke on the realise lever on the latch so check it when you manage to open
4Boot can't open Empty Re: Boot can't open on 10th December 2016, 2:33 pm
Not happening, trying to pull the long thin metal cable. Nothing...
5Boot can't open Empty Re: Boot can't open on 10th December 2016, 2:39 pm
Boot can't open Image14
Boot can't open Image15
Boot can't open Image13
6Boot can't open Empty Re: Boot can't open on 10th December 2016, 3:31 pm
move the lever bar as much as possible and give door a whack near the lock area a few times.
May need use your foot and hold lever bar with small vise grips or similar, sometimes helps have someone outside pushing in which helps jolting action budge it, maybe some spray lube too .
If the lever bar not really moving then need get down and poke around with latch itself to try and get it move .
7Boot can't open Empty Re: Boot can't open on 10th December 2016, 3:35 pm
Cheers, from the picture would the lever bar need to be moved left or right?
8Boot can't open Empty Re: Boot can't open on 10th December 2016, 4:01 pm
Get someone move the key to determine bar movement if can't see by looking at it.
also worth trying having someone pull lever by seat while you nudge it from inside. mixture of this and some release oil may sort it. can you see any debris that may of got caught in latch when last closed .
9Boot can't open Empty Re: Boot can't open on 10th December 2016, 4:46 pm
The lever on the boot latch needs moving clockwise I think?? Get a thin bar and poke into the latch near the bottom trim
