Gtir Motorsport club » General Discusion » Random banter » Let's play guess the Bhp
Go down  Message [Page 2 of 4]
26 Re: Let's play guess the Bhp on 20th December 2016, 8:58 pm
1 rob . 381.4bhp
2 mike74 393bhp
3. Bob 378.1
4. John 401
5. Whytie 369/340
6. Johnny gtir 372
7. Lieghton . 384 bhp
8. Nieil 375
9. Mr B 371
10. Mike 405
11. Woody 380
12. splmum 397.5
13. Toaster 385.5
14. Partypete 367.7
15. Welling_AL 388.5
16. Almera Alan 396
17. Pulsarmoley 374
18 Ducie54 360
27 Re: Let's play guess the Bhp on 20th December 2016, 9:04 pm
If it only makes 340 bhp and runs lovely I'll be happy with that
At the moment it's massively over fueling on idle . Especially when it's cold , afrs when cold are 10.2 , warm it's 11.6 ish
28 Re: Let's play guess the Bhp on 20th December 2016, 9:33 pm
Spark plug spike
Spark plug spike
1 rob . 381.4bhp
2 mike74 393bhp
3. Bob 378.1
4. John 401
5. Whytie 369/340
6. Johnny gtir 372
8. Nieil 375
9. Mr B 371
10. Mike 405
11. Woody 380
12. splmum 397.5
13. Toaster 385.5
14. Partypete 367.7
16. Almera Alan 396
17. Pulsarmoley 374
18 Ducie54 360
19. Spike 400.1
29 Re: Let's play guess the Bhp on 20th December 2016, 9:42 pm
How do you lot think injectors will do close to 400 even maxed out surely not ?
30 Re: Let's play guess the Bhp on 21st December 2016, 7:33 am
Up at 5.30 on the 6.30 ferry should be with bob for 10am
Let's see what she can do ☺
31 Re: Let's play guess the Bhp on 21st December 2016, 8:06 am
Good Luck!! I'm guessing. 377bhp
1 rob . 381.4bhp
2 mike74 393bhp
3. Bob 378.1
4. John 401
5. Whytie 369/340
6. Johnny gtir 372
8. Nieil 375
9. Mr B 371
10. Mike 405
11. Woody 380
12. splmum 397.5
13. Toaster 385.5
14. Partypete 367.7
16. Almera Alan 396
17. Pulsarmoley 374
18 Ducie54 360
19. Spike 400.1
20. DC313 377
32 Re: Let's play guess the Bhp on 21st December 2016, 12:40 pm
Well what a poo start to the day .
We got on the A3 at 8am  and came to a dead stop sat there for over an hour .
Then when it started moving we did about 5mph for the next hour .
So by 10.30 we had travelled 18 miles from portsmouth  .
Spoke to bob and both agreed that today ain't gonna be the day for my car ..
Even if the traffic cleared we still wouldn't have gotten to southend till well after 12.30   . Which would leave not enough time to do what was needed
So turned round and headed back to Portsmouth  .
We did look at other routes off the A3 but every junction was rammed solid with traffic not moving an inch
Gonna have to wait for this result chaps
33 Re: Let's play guess the Bhp on 21st December 2016, 2:15 pm
that's pretty shite luck mate  Sad
34 Re: Let's play guess the Bhp on 21st December 2016, 3:35 pm
Got back to the ferry and we've done 108 kms and used half a tank .
Over fueling slightly
35 Re: Let's play guess the Bhp on 21st December 2016, 5:28 pm
Bloody Christmas traffic... duh
Hope you manage to get to Southend and get it sorted before too long.
36 Re: Let's play guess the Bhp on 22nd December 2016, 7:40 am
Bad luck Rob, not too worry though. Will be something to look forward to in the New Year. Good luck with it.
37 Re: Let's play guess the Bhp on 22nd December 2016, 8:22 am
Not as easy as I know you have kids etc but make it a two day thing mate means any little problems can be hopefully sorted. I know what it's like I drove 4 hours off boost with my new tubby fir to be pissed about. Thankfully bob saved the day
38 Re: Let's play guess the Bhp on 22nd December 2016, 8:27 am
I recommend you replace the engine oil and filter before dyno work if the fueling has been rich.
39 Re: Let's play guess the Bhp on 22nd December 2016, 10:38 am
Worth running through ignition and ecu coolant temp sensor and throttle position switch and new fuel filter etc (maybe an injector flow test/clean) to make sure less chance issues on the tune and get best from it. secondary ignition amplifier, slightly bigger injectors and/or adjustable fuel pressure regulator could help get higher output safely and smoothly if everything else working in harmony.
Like ducie suggests new oil/filter before session would be good, I would do again once returned home too .
40 Re: Let's play guess the Bhp on 23rd December 2016, 6:40 pm
That day was a bummer as we were geared up to get Robs car in around 10ish then give it a thorough checkover prior to it going on the dyno and start playing around with the map etc.
There are nearly always some issues that need attending to prior to any car going on rollers and sometimes you can kiss goodbye to over half the day sorting out small niggly issues.
So in both our interests i advised Rob to head on back to the Island as he may not have made it here till late in the afternoon 'due to a bike accident it seems' which is why the roads were choca.
Already advised Rob to drop the oil as it must reek of fuel as was almost in the 9s at idle with his Afr's. Also told him to try dis-connecting his lambda (narrowband) to see if that leaned it off a tad but not been in touch with him since so not sure whether that worked or not.
Aftermarket fpr was something else we may have needed to fit but you dont know until youve done an initial run to assess afr and we keep them in stock anyway
End of the day i would rather have the car in without having to rush things, it takes longer than you may think to map a car properly so if you rush through things thats when mistakes are likely to be made.
So will get him back in the new year at some point so its all ready for a spring thrashing Laughing
41 Re: Let's play guess the Bhp on 30th August 2017, 11:30 am
So it's finally booked in with Bob .
9 months after original booking mainly because I parked it in garage and forgot about it ..
So hopefully next Tuesday the 5th September we should get a result
42 Re: Let's play guess the Bhp on 30th August 2017, 8:00 pm
Look forward to the result Very Happy
43 Re: Let's play guess the Bhp on 30th August 2017, 8:04 pm
All bets are back on then Laughing fingers crossed it's a better journey than last time .... did you sort the fuelling issue ???
44 Re: Let's play guess the Bhp on 30th August 2017, 9:45 pm
Yeah I sorted it by not driving it for 8 and half months
45 Re: Let's play guess the Bhp on 31st August 2017, 8:02 am
kevmc76
kevmc76
Good luck 375 anymore is a win win for you
46 Re: Let's play guess the Bhp on 31st August 2017, 10:04 am
Rob forgot to say that if shes still overfuelling either bring some oil down with you and we will change it prior to being mapped or if you dont have any then we have 5w50 & 10w60 on the shelf
47 Re: Let's play guess the Bhp on 31st August 2017, 10:57 am
I've ordered some fuchs 10w50 from opie .
And I've also got Nissan pitworks fliters in the garage .
Cheers bob I'll see you on Tuesday
48 Re: Let's play guess the Bhp on 1st September 2017, 9:27 am
So I've taxed it today . Gonna pull it out of the garage and take it for a run to fill her with fuel .
Is it worth dropping the oil now and filling with 10w40 just to get me to bobs ?
Then drain and fill with 10w50 at bobs
49 Re: Let's play guess the Bhp on 1st September 2017, 4:24 pm
If it's chucking fuel in. Oil is cheaper then a bottom end mate
50 Re: Let's play guess the Bhp on 1st September 2017, 4:36 pm
Tbh I've driven it today to put fuel in and afr readings were all good .
Last time I drove it was December and was cold .
Today is 20c warmer than it was in december .. Does the car have anyway of fueling for airtemp ?
Back to top  Message [Page 2 of 4]
