Gtir Motorsport club » Tech room » Help and Advice » Window fuse
Window fuse
1Window fuse Empty Window fuse on 13th January 2017, 4:55 pm
danno
Im trying to find the fuse for the electric windows if anyone can help, sounds silly but I searched the forums for "fuses" and nothing came up and I can't read Japanese Rolling Eyes
2Window fuse Empty Re: Window fuse on 13th January 2017, 5:32 pm
Probably not much help but this is for the fusebox to the right of the steering wheel:
http://www.mummachummas.co.uk/gtir/FUSES.jpg
It might be in the fusebox in the engine bay?
3Window fuse Empty Re: Window fuse on 13th January 2017, 5:33 pm
Its in the engine bay
4Window fuse Empty Re: Window fuse on 13th January 2017, 5:35 pm
Window fuse 2015-02-06%2015.29.00_zpsjkgba5fz
Window fuse 2015-02-06%2015.29.28_zpsui0tueku
Window fuse 2015-02-06%2015.30.13_zpst03a6kty
5Window fuse Empty Re: Window fuse on 13th January 2017, 5:59 pm
danno
Great stuff, thanks guys, I only found the inside fuse box, didn't even know there was one by there. Haven't had the car long.
6Window fuse Empty Re: Window fuse on 13th January 2017, 7:16 pm
danno
So the fuse is OK, I imagine there's a relay somewhere? And if there isn't or its ok too then I don't know where to start next lol.
7Window fuse Empty Re: Window fuse on 13th January 2017, 7:47 pm
Its usually the switches in the driverside door card that's faulty.
Take it out and strip it down. Use electrical spray cleaner and a toothbrush and clean the circuit board.
8Window fuse Empty Re: Window fuse on 13th January 2017, 8:20 pm
danno
Thanks, I'll try that, I didn't realise it had a fan dangle circuit board controlling everything.
9Window fuse Empty Re: Window fuse on 16th January 2017, 10:36 am
FUSE BOXES.PDF
https://drive.google.com/file/d/0B7Ub2apq5-pfVm51U2U3dE45TjQ/view?usp=sharing
10Window fuse Empty Re: Window fuse on 16th January 2017, 9:59 pm
Daveymeladdy
Daveymeladdy
What is the fuse for the rear speaker / amp? Didn't know about that one!
11Window fuse Empty Re: Window fuse on 17th January 2017, 7:54 am
^ Assume that for the optional parcel shelf speaker kit when was fitted .
