Gtir Motorsport club » Tech room » Help and Advice » G sensor on abs
G sensor on abs
1 G sensor on abs on 27th January 2017, 3:36 pm
danno
So ive fitted the new sensor, not sure if i wired it the right way, but i now have a G sensor fault, 11 flashes on the abs ecu.
So my question is where or what is the G sensor so i can follow the fault check procedure.
Thanks.
2 Re: G sensor on abs on 27th January 2017, 5:49 pm
I'm not sure what the g sensor is.
But found this on the Internet.
"ABS G sensor, its located under the ashtray/centre console area."
3 Re: G sensor on abs on 27th January 2017, 6:01 pm
Right I think this is the G sensor.
Just taken it out of the spare gtir I have and it is under the ashtray part.
Check the wire and plug as the "circuit" would suggest it's the wires.
If you need a sensor tho. Message me and I will sell you this one?
4 Re: G sensor on abs on 27th January 2017, 7:07 pm
danno
All sorted, thanks stu, it was unplugged and i now have no faults which also means the almera n15 abs sensor works.
5 Re: G sensor on abs on 27th January 2017, 7:25 pm
Happy to help mate Wink
Good to know the almera sensors work too Smile
