Gtir Motorsport club » Tech room » Help and Advice » Almera n15 front abs sensors
1Almera n15 front abs sensors Empty Almera n15 front abs sensors on 27th January 2017, 7:21 pm
danno
They work Very Happy
And all i did was cut the plugs off and joined the old plug onto the new sensor wiring
They are the same length and clamp on the strut tower in the same place, the other bracket is not used on mine as i have gab struts and there is no clamp for it so itll just be cable tied to the strut.
Now as for which way the wires go i dont know, as ive wired it both ways and it still works.
Also, the colour of the wires on the sensor could be different between manufacturers, mine were grey and brown on the new one.
2Almera n15 front abs sensors Empty Re: Almera n15 front abs sensors on 27th January 2017, 7:28 pm
Great info mate Smile
3Almera n15 front abs sensors Empty Re: Almera n15 front abs sensors on 27th January 2017, 7:39 pm
Was the plug you cut off the n15 like this?
Almera n15 front abs sensors Screenshot_2017-01-27-19-37-37_zpsfyzbzcxn
Looks the same as the gtir ones.
4Almera n15 front abs sensors Empty Re: Almera n15 front abs sensors on 27th January 2017, 7:43 pm
For reference:
FRONT RIGHT ABS SENSOR NISSAN ALMERA N15 47910-0M000
FRONT LEFT ABS SENSOR NISSAN ALMERA N15 479110-M000
5Almera n15 front abs sensors Empty Re: Almera n15 front abs sensors on 27th January 2017, 7:52 pm
danno
Yes, thats the same plug i cut off, but the pulsar one has a female connector not a male as on the almera one, thats the only difference other than the wire colours.
6Almera n15 front abs sensors Empty Re: Almera n15 front abs sensors on 27th January 2017, 9:02 pm
That good to know, did mention in another thread should be likely fit one with some tweaking, just plug swap is super simple ...
