Gtir Motorsport club » General Discusion » Gtir related Discussion » Door stuck
Door stuck
1Door stuck Empty Door stuck on 5th February 2017, 7:40 am
Anyone got any advice with my problem opening the passenger side door?
When you gently open the door handle its stuck but when you give it a quick yank it opens.
Ive lubed up the locking mechanism and made no difference.
Easier to explain via video Laughing
https://vimeo.com/202603468
2Door stuck Empty Re: Door stuck on 5th February 2017, 7:43 am
Dose it drop any when you open it ?
3Door stuck Empty Re: Door stuck on 5th February 2017, 8:18 am
no drop mate Smile
4Door stuck Empty Re: Door stuck on 5th February 2017, 11:22 am
Take off the inner card get in the drivers side and get someone to open the door as in your video.
Watch the action and see if the lever arms are moving the same in both operations.
Could be a bent arm or a bent housing.
If so, adjust the arm or the housing until it strikes on gentle movement.
just an option.
5Door stuck Empty Re: Door stuck on 5th February 2017, 2:00 pm
Yes as the man above says inc check all the plastic clips and the inside of handle
6Door stuck Empty Re: Door stuck on 5th February 2017, 10:02 pm
Thanks guys, I'll have to do some investigating then.
