Gtir Motorsport club » Tech room » Help and Advice » Air idle control valve
1 Air idle control valve on 8th February 2017, 10:00 pm
Can some one please tell me which one is the idle control valve please as getting a price from Nissan
2 Re: Air idle control valve on 8th February 2017, 10:10 pm
22660M by the look of the diagram
3 Re: Air idle control valve on 8th February 2017, 10:18 pm
@nomad wrote:22660M  by the look of the diagram
Ain't that cold start device?? I'd say thing highlighted in blue - 23781m I believe Stu was looking for it other day
This one is for s14...
4 Re: Air idle control valve on 8th February 2017, 10:21 pm
Cheers nomad....I may try cleaning it out first, see if that helps, I get high idle or no idle at all and cuts out, I'm thinking it may have something to do with that, I've been told it's had it any way
5 Re: Air idle control valve on 8th February 2017, 10:23 pm
Best get a few more opinions incase, the parts Bloke said he wasn't sure which one it was
6 Re: Air idle control valve on 8th February 2017, 10:32 pm
@PartyPete wrote:Cheers nomad....I may try cleaning it out first, see if that helps, I get high idle or no idle at all and cuts out, I'm thinking it may have something to do with that, I've been told it's had it any way
Bring it to me Saturday I'll set it on fire for you together with mine and Beata's....
7 Re: Air idle control valve on 8th February 2017, 10:46 pm
22660m is the air regulator
22662 is the aac valve
23781m is the cold start solinoid valve
Is how I see that
8 Re: Air idle control valve on 8th February 2017, 10:50 pm
AAC valve is 23781m... https://www.nengun.com/cart/
9 Re: Air idle control valve on 9th February 2017, 7:31 am
@nomad wrote:AAC valve is 23781m... https://www.nengun.com/cart/
That link just takes me to a blank page nomad?
10 Re: Air idle control valve on 9th February 2017, 8:02 am
He is right
22662 IACV-AIR REGULATOR ADAPTER
23781M  IACV-AAC VALVE
23781M also referred to on some as the fuel injection ideal speed control valve
11 Re: Air idle control valve on 9th February 2017, 8:53 am
12 Re: Air idle control valve on 9th February 2017, 8:54 am
Sorry pete thats what it was meant to show ....
13 Re: Air idle control valve on 9th February 2017, 9:05 am
its a bit fiddly to remove that whole unit from underneath the inlet manifold (I found anyway).
You could try removing the idle screw and squirting some carb cleaner in first to see if that does anything
14 Re: Air idle control valve on 9th February 2017, 9:44 am
Iacv-aac valve 2378154C00
Get it off and test and clean it with loads of carb/throttle body cleaner and compressed air, little shot of wd40 may help.
I expect they over £200 new and likely long wait/hard source as R specific, I would try source a known good used one if yours turns out be faulty .
Worth checking ecu temp sensor signal and tps setup, what maf you got, you run without lambda ?
assume it runs fine when open throttle !?
15 Re: Air idle control valve on 9th February 2017, 10:02 am
Nissan don't sell them anymore.
You can get them on ebay for around £180 I think tho.
16 Re: Air idle control valve on 9th February 2017, 2:49 pm
weve got known good working units in stock if needed
17 Re: Air idle control valve on 9th February 2017, 3:27 pm
Right! I'm going to try cleaning it up first and see if that helps, if not how much do you sell them for bob?
18 Re: Air idle control valve on 9th February 2017, 9:00 pm
200sx s14 is the same and i have one on at the moment.
19 Re: Air idle control valve on 10th February 2017, 7:47 am
^ s14 200sx 180 sx silvia have different part # 2378169F10 (although first 5 important p/n digits same)
looks much same (never compared them side by side though) so interesting know it fits/works .
20 Re: Air idle control valve on 12th February 2017, 6:54 pm
Well I've taken it out, stripped it completely,cleaned it and wd40'd it, put it back together and it still just cuts out after idling for a short while, the afr starts leaning out and then it just cuts out! And it's only done this since the turbo went! That's been fully rebuilt (with a bigger exhaust wheel) so what the hell could it be??? I'm going to take it for mapping next month but ideally would like to get it sorted before then.....
21 Re: Air idle control valve on 12th February 2017, 7:39 pm
Vac leak?
22 Re: Air idle control valve on 12th February 2017, 8:26 pm
I seem to remember a couple guys that removed all that idle control gubbins completely and never had any issues with stalling or dodgy idle, definitely sounds like something else is wrong. I'd tend to agree with Stu, it does sound like an air leak somewhere...maybe between turbo and maf if you've had that pipe off?
23 Re: Air idle control valve on 12th February 2017, 8:53 pm
It just seems extremely coincidental that as my turbo went this also happens...I'll check the maf to turbo pipe, I'll give the maf a good clean as well and check as much piping as possible, but I'm sure there's more to this than a leak....
24 Re: Air idle control valve on 12th February 2017, 11:39 pm
Is it possible that while changing the turbo you knocked the dizzy cap or the dizzy itself ie timing out?
25 Re: Air idle control valve on 13th February 2017, 6:26 am
@mike74 wrote:Is it possible that while changing the turbo you knocked the dizzy cap or the dizzy itself ie timing out?
I didn't go near it tbh, I'd of thought you'd have to hit it pretty damn hard to knock the timing out wouldn't you?
