Gtir Motorsport club » General Discusion » Gtir related Discussion » Power problem
Power problem
Go down  Message [Page 5 of 6]
101Power problem - Page 5 Empty Re: Power problem on 12th March 2017, 12:30 pm
102Power problem - Page 5 Empty Re: Power problem on 12th March 2017, 1:37 pm
ADSgtir
It's a bit tricky to diagnose idle quality : your cams have been moved , we don't know where , this can effect the idle vacuum - that is the amount of air that the engine pulls in to run at idle .
Also you map has been set for your injectors (larger)at that idle vacuum and maybe even with a vacuum leak on top (split hose )
You really need a good tuner to find out where you are currently and start from scratch and make adjustments as necessary : throttle cable , cold start values , idle targets , vacuum , fuel pressure etc
103Power problem - Page 5 Empty Re: Power problem on 12th March 2017, 3:37 pm
Was running okay for some time after the cam sprockets/tune and this issue developed after turbo failure.
Could be worth looking at idle assembly incase turbo debris or general old age affecting it . Also lambda worth checking if using one .
104Power problem - Page 5 Empty Re: Power problem on 12th March 2017, 4:16 pm
Had the idle assembly out and stripped a couple weeks ago and all was fine. The idle adjustment screw is that chewed up and fucked I can't turn it to adjust to see if that helps!
105Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 8:46 am
So...looks like I've cured the idle issue....any one want to take a guess at what was causing it? ( it wasn't any of the parts I've replaced that I listed above)....
106Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 9:10 am
Leprechaun put a hex on your lambda sensor?
107Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 9:14 am
Was it the onset of Alzheimers making your foot shake? Very Happy Very Happy
108Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 9:34 am
Close guys but not quite.....any others?
109Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 10:09 am
Glow plugs? Or sticky vtec solenoid??
110Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 10:12 am
Fuel pump? bad earth?
111Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 11:51 am
Vacuum box behind the plenum?
112Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 12:09 pm
^ another air leak so pulling air not being metered at idle !
113Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 1:48 pm
For what ever reason the idle screw was screwed all the way in, it was all mashed up but managed to get a sharp screw driver in and turn it out....and hey presto it suddlenly started idling like a brand new un'
114Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 1:53 pm
@Mr B wrote:^ another air leak so pulling air not being metered at idle !
Thats exactly what was wrong with mine B.
115Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 1:57 pm
@PartyPete wrote:For what ever reason the idle screw was screwed all the way in, it was all mashed up but managed to get a sharp screw driver in and turn it out....and hey presto it suddlenly started idling like a brand new un'
I was going to say that but assumed it would be the first thing you tried
116Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 2:00 pm
Kind of makes sense as with air leaks it likely revving high so someone at some point counteracted it by winding in that idle screw .
I seen similar on a car with a split diaphragm recirc valve and idle had been restored by winding screw in all way, took me quite some time after fitting a new external valve to figure that out though lol.
well done for chasing it down, should be looking good for next mapping session, fingers crossed for pleasing results ... persistence will payoff bounce
117Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 2:00 pm
this has got to be the only R ever made to have an idle issue resolved by turning the idle screw  Shocked
glad its sorted though
118Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 2:02 pm
So yours was vacuum box, was it pipe missing or a split or something ?
119Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 2:04 pm
We didn't look at it and think ' let's try that' but as we tried it was that chewed up and fucked we couldn't turn it, had to get a screwdriver on the grinder and get it very sharp and hammer it in to the plastic screw to get it to turn, only just managed to turn it
120Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 3:27 pm
Pipes missing.
The large ones on the side.
So was a mass of un metered air.
121Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 6:02 pm
@PartyPete wrote:We didn't look at it and think ' let's try that' but as we tried it was that chewed up and fucked we couldn't turn it, had to get a screwdriver on the grinder and get it very sharp and hammer it in to the plastic screw to get it to turn, only just managed to turn it
They plastic ? Sure mine ain't
122Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 6:03 pm
I might be wrong but I think there suppose to be plastic blanking plug
123Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 6:16 pm
All I have looked at are deninately metal?
Glad its sorted anyway or getting better
124Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 6:23 pm
@shroom wrote:All I have looked at are deninately metal?
We will find out next Friday...
125Power problem - Page 5 Empty Re: Power problem on 17th March 2017, 10:22 pm
I will have a look at mine tomorrow. Will you be bringing the R to Japfest ?
Back to top  Message [Page 5 of 6]
