Gtir Motorsport club » General Discusion » Gtir related Discussion » fitting side skirts
fitting side skirts
26fitting side skirts - Page 2 Empty Re: fitting side skirts on 5th March 2017, 8:02 am
Good luck mate
Lube or try one I know they need to be tight once in but even very gone sand the male one if you get stuck
27fitting side skirts - Page 2 Empty Re: fitting side skirts on 7th March 2017, 7:41 am
Thanks mate Smile
Went to order more clips and they are out of stock from Nissan.
I tried to fit one side skirt this arvo, with the both clips attached to the side skirt and some went in but not enough to hold the side skirt correctly to the car. It looks like my problem is the sill is actually push in around the side skirt holes from someone trying to fit them previously, I'm guessing brutally with a hammer. So the clips wont sit into the sill fuming
I haven't tried the other side. I'm going to glue them and forget about it Laughing
28fitting side skirts - Page 2 Empty Re: fitting side skirts on 7th March 2017, 8:33 am
sounds like you'll be buying some tigerseal shortly thenĀ  Sad
29fitting side skirts - Page 2 Empty Re: fitting side skirts on 17th March 2017, 7:18 am
@Stu wrote:These are what I bought.
http://www.ebay.co.uk/itm/122023181034
Thanks Stu I just order some of these. So much cheaper than Nissan aswell.
I had a new thought this arvo, I'm going to wedge metal or cardboard behind the male clips (similar to the pic below) to hopefully give the clip a few move mm to push in, I'm hopeful this will solve my problem Smile
fitting side skirts - Page 2 IMG_3623
30fitting side skirts - Page 2 Empty Re: fitting side skirts on 17th March 2017, 7:37 am
Use plastic
carboard might dissapeer eventually but holds water and a metal thin enough will prob rust
I know your not in the U.K. but paint or protect around them with sealer
31fitting side skirts - Page 2 Empty Re: fitting side skirts on 17th March 2017, 8:22 am
That's a good point mate, thanks!
