Gtir Motorsport club » Tech room » Help and Advice » Knock Sensor
Knock Sensor
1 Knock Sensor on 4th March 2017, 12:11 pm
joetheeskimo
joetheeskimo
Hi Guys
the connector for my knock sensor broke, can anyone tell me which pin i should connect to for the output.
How can i go about checkin the output of the knock sensor with the engine running to ensure its working. Is the knock sensor read by the ECU during start up conditions.
Thansk
2 Re: Knock Sensor on 4th March 2017, 12:21 pm
I can't remember which pin it is but, if you connect it to the wrong pin fault code 34 will constantly pop up. The ecu will think the sensor isn't connected. One of the pins is an earth IIRC
3 Re: Knock Sensor on 4th March 2017, 12:42 pm
joetheeskimo
joetheeskimo
@mike74 wrote:I can't remember which pin it is but, if you connect it to the wrong pin fault code 34 will constantly pop up. The ecu will think the sensor isn't connected. One of the pins is an earth IIRC
As the centre of the sensors is metal, I am assuming i shouldn't need to connect the earth pin as the sensor it self will earth when Attached to the engine.
4 Re: Knock Sensor on 5th March 2017, 8:04 am
Looking at sensor the left pin is the signal and rght earth/shield I think from memory, have a look in the FSM on the det sensor tests .
