Gtir Motorsport club » Tech room » Help and Advice » AEM boost solenoid with profec 2
1 AEM boost solenoid with profec 2 on 9th March 2017, 7:06 pm
Hi guys.
I have bought a greddy profec b2 that has an aem boost solenoid.
Does anyone know if I wire the solenoid straight to the boost controller wires.
The wires are green and white from the boost controller.
The aem has 2 brown wires and instructions say any one of those wires can be put to positive feed.
The profec b2 has a live and earth wire so I guess that will be the switching live feed for the solenoid.
2 Re: AEM boost solenoid with profec 2 on 9th March 2017, 9:23 pm
You got a multi meter mate ?
3 Re: AEM boost solenoid with profec 2 on 9th March 2017, 9:30 pm
No mate.
The guy I bought it off has confirmed that those two wires go to the solenoid as I suspected.
I down loaded the profec pdf aswell and it says they are for the solenoid.
Am says on their pdf that it doesn't mater which way you wire it up.
4 Re: AEM boost solenoid with profec 2 on 9th March 2017, 9:37 pm
They 100% do was just going to say put the controller across a battery and test the voltage on the two wires that feed the solinoid
5 Re: AEM boost solenoid with profec 2 on 9th March 2017, 9:54 pm
Ah okay.
The guy I bought it off had been using it for a long time so woukd have thought it was okay?
As long as I get a 12V feed to the controller?
6 Re: AEM boost solenoid with profec 2 on 10th March 2017, 8:12 am
Yes mate if both are 12 v put it across a battery try it then try solenoid then wire that to controller all off the car then fit it all mate
7 Re: AEM boost solenoid with profec 2 on 10th March 2017, 9:28 am
Thanks Johnny Smile
