Gtir Motorsport club » General Discusion » Gtir related Discussion » would this fit the R
1would this fit the R  Empty would this fit the R on 11th April 2017, 12:58 pm
SonaGTIR
http://www.frsport.com/?target=products&product_id=1538¤cy=GBP&gclid=CMHxnbq5nNMCFQOfGwodQxUM1Q
as above would this fit
2would this fit the R  Empty Re: would this fit the R on 11th April 2017, 1:38 pm
It looks like it's for a 200sx, so the turbo wouldn't sit in the normal place, so then you'd end up altering all sorts
3would this fit the R  Empty Re: would this fit the R on 11th April 2017, 1:53 pm
SonaGTIR
whats the best upgrated for the r manifold. for only 320hpish
4would this fit the R  Empty Re: would this fit the R on 11th April 2017, 2:52 pm
Its for the 240sx and 180sx also inc the silivia ..
5would this fit the R  Empty Re: would this fit the R on 11th April 2017, 3:31 pm
I've always thought the standard manifolds are good for 400+bhp?
6would this fit the R  Empty Re: would this fit the R on 11th April 2017, 4:08 pm
They are mike especially if they have been ported
7would this fit the R  Empty Re: would this fit the R on 11th April 2017, 5:21 pm
@SonaGTIR wrote:whats the best upgrated for the r manifold. for only 320hpish
Send it to Mike(Gostek) he'll port it for you lol!
Well once he'll find 5 min that is...
8would this fit the R  Empty Re: would this fit the R on 11th April 2017, 8:07 pm
I know people have done it fine but I wouldn't be bothering with a Silvia etc manifold.
9would this fit the R  Empty Re: would this fit the R on 12th April 2017, 7:13 am
SonaGTIR
I've never considered having it ported. I was under the car searching for a leak the other day and noticed that the manifold has really seen better days.. how much is it to port? What are the gains if any? Smoother flow.. still need to heat wrap a few things
10would this fit the R  Empty Re: would this fit the R on 12th April 2017, 10:49 am
Weve done a fair few of them now and definately increases the gas flow over the rough cast stock item.
Open the ports up around 2mm and match head ports (without going right into the main gallery of head) You will find that carbon deposits dont build up as much either.
Combined with a free flow elbow youll get faster spool up time and also if you have larger duration cams fitted youll get the best from those too
11would this fit the R  Empty Re: would this fit the R on 12th April 2017, 11:37 am
Yep port standard best you can (weld fill recess for max port work) and blast it clean and do a real neat job with some charcoal black heat wrap then add a quality elbow and they will do over 450hp and look decent under bonnet too plus don't crack or fall off or sound like a bees nest like the cheap stainless shite .
12would this fit the R  Empty Re: would this fit the R on 12th April 2017, 12:34 pm
I'm making outside of ports tad bigger  ( usually by 2mm nor much more) but I do lower the floor between cylinder 2 and 3 and I weld recess on the collector and grind it smooth inside. Also I smooth it with something like 120 grid emery cloth... I take for it £50 ( and obviously delivery).
It looks like that
https://youtu.be/hnIclr8ddno
13would this fit the R  Empty Re: would this fit the R on 12th April 2017, 3:59 pm
SonaGTIR
Thanks guys. I'm looking at going forward possiblely. I have a 3 inch turbo elbow from bobby. 0.9 bar making 286hp. If it's a matter of sending it away to gostek and then when I receive it back bolt it straight on then I could do that. But I will not be able to modify the actual head as I don't have the knowledge or the tools.
Would a stock gasket fit back on.
14would this fit the R  Empty Re: would this fit the R on 12th April 2017, 7:44 pm
@SonaGTIR wrote:Thanks guys. I'm looking at going forward possiblely. I have a 3 inch turbo elbow from bobby. 0.9 bar making 286hp. If it's a matter of sending it away to gostek and then when I receive it back bolt it straight on then I could do that. But I will not be able to modify the actual head as I don't have the knowledge or the tools.
Yes standard gasket will fit ok, you can actually sent it to me so I'd match manifold to it. Whereabouts you're located bud?
15would this fit the R  Empty Re: would this fit the R on 12th April 2017, 8:01 pm
SonaGTIR
I'm in Coventry mate.. just to confirm I don't need to modify the engine at all. It's bolt on. I don't need to adjust/ bore/ re-map.. anything?
Sorry if I sound dumb.. it's because I prob am
16would this fit the R  Empty Re: would this fit the R on 12th April 2017, 8:06 pm
@SonaGTIR wrote:I'm in Coventry mate.. just to confirm I don't need to modify the engine at all. It's bolt on. I don't need to adjust/ bore/ re-map.. anything?
It's ok bud don't worry. You can bolt it to standard unmodified car/engine. Few guys from here (from Coventry funny enough) are running this manifold and didn't report any problems yet...
17would this fit the R  Empty Re: would this fit the R on 12th April 2017, 9:53 pm
SonaGTIR
Pm me your details bud.
