Gtir Motorsport club » General Discusion » Gtir related Discussion » dipstick
dipstick
1dipstick Empty dipstick on 13th April 2017, 8:10 am
SonaGTIR
has anyone ever had a issue with the dip stick being too far back?
before I had some work done to the car a few years ago the dipstick was clearly visible and accessible.
Since that work was done it further back under the manifold and hard to get at?
any thoughts
2dipstick Empty Re: dipstick on 13th April 2017, 9:10 am
will it not bend forward a bit?
3dipstick Empty Re: dipstick on 13th April 2017, 11:30 am
SonaGTIR
the dip stick goes in and out after a bit of a struggle. but im sure it used t o be visible and there. If you mean bending the actual tube then no. I haven't tried that
4dipstick Empty Re: dipstick on 14th April 2017, 1:04 am
Take a pic mate.
Mine is abit of struggle to get in and out aswell
5dipstick Empty Re: dipstick on 14th April 2017, 6:27 am
What kind of work ? A lot of people try and put the tube in wrong thinking the flat bit at the very bottom goes towards the block which it don't
6dipstick Empty Re: dipstick on 16th April 2017, 11:32 pm
Yeah you might want to take it out and move it about its probably been put in wrong like Johnny said.
Easy anough to to just tap it up and out then re fit, you may want to oval the end slightly so it doesnt keep coming out and tap it down gently
7dipstick Empty Re: dipstick on 17th April 2017, 8:40 am
Also clean the end and put a little thread seal on to ensure it stays in place and doesnt leak.
8dipstick Empty Re: dipstick on 18th April 2017, 11:33 am
SonaGTIR
sounds lads
