Gtir Motorsport club » Tech room » Help and Advice » Smoking engine
Smoking engine
1Smoking engine  Empty Smoking engine on 15th April 2017, 12:33 pm
any advice welcome. Fitted secondhand standard engine. Smoking as you come off boost and abit on tickover
Comp tested fairly even across cyl 3 down slightly. It's Not the turbo. Nothing like oils in cooler ( runs top mount) or exhaust. Could it be valve stems ? Sticking valve or am I way off ?
Dose not do it from cold on tickover even if it's stood.
Anything to check or advice would be great.i ain't stupid can do most things but
Internals of engine and box are not my strongest point leave them to people with more knowhow and skills
2Smoking engine  Empty Re: Smoking engine on 15th April 2017, 6:20 pm
Has the engine been sitting long .... colour of smoke ???
3Smoking engine  Empty Re: Smoking engine on 15th April 2017, 7:01 pm
Blue so oil mate. Similar to turbo probs but had two on now and second is 100% tested as good unit. First still feels good and smoke should of cleared if in exhaust
4Smoking engine  Empty Re: Smoking engine on 15th April 2017, 7:31 pm
Could it be the oil control rings? You'd still have good compression but could get oil into cylinders if there worn (i believe) smoking on start up usually means valve stem seals but you've said it's not doing that?
5Smoking engine  Empty Re: Smoking engine on 15th April 2017, 7:36 pm
could be valve guide which normally smokes on overrun
Could also be rings/bore/piston on your low cylinder from bit of classic ringland damage.
Have a look at plugs for clues and bore scope it for more clues .
6Smoking engine  Empty Re: Smoking engine on 15th April 2017, 8:28 pm
Thanks will update tomorrow. Don't think comp is low enough to cause problem it's not that far out tobother 3
7Smoking engine  Empty Re: Smoking engine on 15th April 2017, 9:58 pm
Whats the comp test readings ....
8Smoking engine  Empty Re: Smoking engine on 16th April 2017, 3:05 pm
Rushed writing this yesterday as was looking for fix and busy more tests done seems to be valve stems and guide according to a mate
Thanks for the replies.
9Smoking engine  Empty Re: Smoking engine on 16th April 2017, 5:55 pm
^ that was most likely linking to overrun smoke . easy sort guides/seals and better than bore/piston issues .
10Smoking engine  Empty Re: Smoking engine on 16th April 2017, 7:23 pm
Yes thanks mate
11Smoking engine  Empty Re: Smoking engine on 17th April 2017, 12:56 pm
thing is if the stem seals had been leaking you would still have a wet ex port on that cylinder which im sure you would have noticed on removal of the turbo Johnny Neutral
12Smoking engine  Empty Re: Smoking engine on 17th April 2017, 1:24 pm
Will bell you during the week mate
13Smoking engine  Empty Re: Smoking engine on 17th April 2017, 2:20 pm
Did you transfer all the breather & PCV system from the old unit to the replacement one (like the little black canister on front top-right of engine)? Maybe breather blocked and causing heavy breathing through engine?
14Smoking engine  Empty Re: Smoking engine on 17th April 2017, 11:39 pm
bore scope it be sure, generally easy enough see oiling on valve if turn engine over for best view.
Generally plug or top of piston good enough clue pinpoint the cylinder/cylinders with likely issue.
