Gtir Motorsport club » General Discusion » Random banter » laid up since December started today and water leak developed
So the last time I drove the R was when I attempted to go see bob to get it mapped ..
That was in December . Since then she's sat in the garage and not moved .
So today I took it out of the garage started it up gave her wash and took for a quick run to get some heat into her before putting her back in the garage till I can get it to bobs ..
Once I got in to the garage I noticed a water leak  coming from somewhere  above / around or near the water pump .
Now I fitted a new waterpump when i did the rebuild so I'm hoping just a leak in a jubilee clip or something .
It's got all new Water hoses etc .
Anything else I could look at?
On the water pump theres a small hole in them that pisses water out if the engine is left standing for a long time maybe its that dont know why they do it wether the seal dries out or something ... probably end up replacing mine aswell they are not that expensive ....
( spot on what your saying the seal mate) As above even on new pump it might expand again when it gets used but in my opinion they don't mate
Two holes one top one bottom there if bearing starts to fail but also if newer pump its likely seal not bearing
Well I've spent 4 hrs doing the waterpump  .
It was leaking from near where the top bolt that holds the powersteering bracket to the pump is  .
So cleaned up all the surfaces and cleaned all the bolts out so they go right in .
I think the problem was where it was leaking the bolt wouldn't go all the way in coz of old sealant in the block . So subsequently  it wasn't as tight as it could have been .
laid up since December  started today and water leak developed  20170423
laid up since December  started today and water leak developed  20170422
All good now tho .
Left it idling for 25 mins then took it for a blast and now no leaky leaky
Glad it's sorted
Glad you sorted her out least i was in the ball park with it Wink
Most of the time taken was making sure no old sealant was in any of the bolt holes .. wanted to make sure all the bolts had lots of room to tighten up
Part of reason why I like the ADL one with the gasket, rub light bit of grease either side of those gaskets and you never get an issue plus it super easy using gasket when engine in car compared to sealant .
Least it jobbed hopefully .
So she's tucked back in the garage .
Just need to contact bob to arrange a session on the rollers
Bring on 400bhp
laid up since December  started today and water leak developed  2017-010
