bool(false) ongoing build - Page 7
Gtir Motorsport club » Gallery » Projects » ongoing build
ongoing build
Go to page : Previous  1, 2, 3, 4, 5, 6, 7
Go down  Message [Page 7 of 7]
151ongoing build - Page 7 Empty Re: ongoing build on 11th July 2015, 10:22 pm
Looks good mate nice to see it all coming together .... and atleast if you have to work on it after you wont get smothered in grease and dirt Wink
152ongoing build - Page 7 Empty Re: ongoing build on 20th July 2015, 11:47 pm
So this weekend was going to be the weekend after a few set backs with the gearbox last weekend.  Worked all day Saturday and everything was ready minus the fluids
So Sunday started looking like this
ongoing build - Page 7 IMAG0573
So filled and bled the clutch, filled up the oil and anti freeze and the car was ready to be primmed....or so I thought.
Ended the day like this
ongoing build - Page 7 IMAG0576
Major fuel leak and had to drop the tank, sub frrame etc... So still not been able to start the engine yet, but so far it's cranked over and held oil pressure (no plugs, ht leads or fuel pump connected
153ongoing build - Page 7 Empty Re: ongoing build on 21st July 2015, 2:46 am
Good to be making progress. Not good about the fuel leak though. I'm sure it will all be done before you know it Smile
154ongoing build - Page 7 Empty Re: ongoing build on 21st July 2015, 6:30 pm
Have you found the cause of the leak Mark?
155ongoing build - Page 7 Empty Re: ongoing build on 21st July 2015, 10:26 pm
Yeah mate the fuel hose I used when I replaced it 2yrs ago has completely perished, so dropped the tank and replaced every hose (so be careful when Buying fuel hose)
Tonight I've managed to get the tank back in and everything back on bar the front arb so tomorrow should be good to actually get back on the road
Primed the engine and gave it a crank over and boom on the button it starts up, top end sounds so quiet and so far so good, so going a bed a happy bunny and looking forward to getting it on the road tomorrow evening
156ongoing build - Page 7 Empty Re: ongoing build on 22nd July 2015, 7:52 pm
good luck with it mark
are you sure the fuel hose you fitted before was actually fuel hose?
157ongoing build - Page 7 Empty Re: ongoing build on 22nd July 2015, 7:58 pm
I need to replace the hoses on the top of my tank, although some look in really good condition, did you get yours off eBay Mark?
Gaz
158ongoing build - Page 7 Empty Re: ongoing build on 22nd July 2015, 10:25 pm
It said it was when I bought it Bob but with the way it's perished now I've removed braid over the top it clearly wasn't.
Yeah gaz it was cant remember where from exactly but be careful and only but from reputable companies.
Well after a shit day at work I didn't get home early enough to get it finished off and running, was so pissed off and going to have a bitch at my boss tomorrow, but tomorrow night is the night....unless something else happens lol
159ongoing build - Page 7 Empty Re: ongoing build on 23rd July 2015, 6:09 am
Good luck and bitch at my boss as every night is late finishes with him
160ongoing build - Page 7 Empty Re: ongoing build on 23rd July 2015, 8:52 pm
Well got home tonight And finally got the old girl running up to temperature while in the air to check for any leaks. Waited for the fans to kick in and bled the system as best I could. Lowered the car to the floor , checked all fluids for a final time and got all ready for my first drive since last June......
Fired up got in the driver's seat, adjusted me mirror smiling like a big kid at Christmas, went for first gear...... Only to find it wouldnt bloody go into gear, actually, I couldn't get any gear... Fuck!!!
All sorts of thoughts went through my mind, clutch/bearing/pivot/selector fork. Pumped the pedal furiously and eventually got 4th gear, so relaxed a little bit in the hope it just needed another bleed.
After a good bled it was selecting gears but wasn't fantastic (which in fairness I've complained for a while about horrible pedal and assumed it was just my pedal clutch). We then adjusted the rod for the master cylinder as it was full adjusted, once wound out this raised my pedal and the clutch now feels and acts like it should, which I'm chuffed about, as ive hated driving the car recently..until now.
Missed my mot but rebooked for tomorrow and I'm now enjoying life as an R owner again
161ongoing build - Page 7 Empty Re: ongoing build on 23rd July 2015, 8:54 pm
Good to hear mark cheers
162ongoing build - Page 7 Empty Re: ongoing build on 23rd July 2015, 8:54 pm
Congrats mate
163ongoing build - Page 7 Empty Re: ongoing build on 23rd July 2015, 9:13 pm
Needs a good clean and detail and the bonnet has gone all milky, so might have to get this painted if a wet sand/da doesn't work
ongoing build - Page 7 IMAG0597
164ongoing build - Page 7 Empty Re: ongoing build on 23rd July 2015, 9:42 pm
hreggtir
hreggtir
nice one Mark, in time as well thumbsup
165ongoing build - Page 7 Empty Re: ongoing build on 24th July 2015, 7:36 pm
So 20 miles in and I've been reminded why I still own this car, not even come on boost yet And loving it.
Passed the mot with just an advisory on the horn not working, which I'm not sure why and also the Speedo isn't working (flicked on for 3 seconds today), wonder if I've paint over an earth point and its not contacting
Not wrong there mate any later and I dont know what I would be coming in, so long as the running in goes well the pulsar should be coming the ring
166ongoing build - Page 7 Empty Re: ongoing build on 9th August 2015, 9:34 pm
I'm now over 500 miles in and going well, dropped the fluids over the weekend and no major lumps in the oil to worry about.
Had new track rods end and drop links fittedand had the tracking done. Alone with 4 new Bridgestone potenzas
Also had a crack at the milky carbon bonnet with a da and medium cutting compound.
ongoing build - Page 7 IMAG0684
ongoing build - Page 7 IMAG0687
167ongoing build - Page 7 Empty Re: ongoing build on 9th August 2015, 10:08 pm
hreggtir
hreggtir
looking good Mark thumbsup
168ongoing build - Page 7 Empty Re: ongoing build on 9th August 2015, 10:46 pm
Looks good  bucky what paste did you cut it with ????
169ongoing build - Page 7 Empty Re: ongoing build on 16th March 2016, 12:14 am
Well with the colder dark days hopefully behind us, its time to uncover and get tge car sorted
Covers coming off and get the battery charged up
https://servimg.com/view/18490709/3
Before winter i threw in some bucket seats and harnesses
https://servimg.com/view/18490709/5#
https://servimg.com/view/18490709/6#
Installed a new front mount (silly logo was painted over)
https://servimg.com/view/18490709/7#
Bonnet open and grill rested in place, trimmed back of the bumper ascwanted to keep the standard look
https://servimg.com/view/18490709/8#
170ongoing build - Page 7 Empty Re: ongoing build on 16th March 2016, 12:21 am
Will sort thumb nail out tomorrow as on tablet
Back to top  Message [Page 7 of 7]
