Gtir Motorsport club » Gallery » Projects » ongoing build
ongoing build
Go down  Message [Page 3 of 7]
51ongoing build - Page 3 Empty Re: ongoing build on 1st July 2013, 9:34 pm
Well its a business my company uses as the parts suppliers of the machinery we sell can be extortionate. I'll sort a link at some point, getting used to my new tablet as my laptop has packed up.
52ongoing build - Page 3 Empty Re: ongoing build on 4th July 2013, 5:19 pm
Put that company under the section. Mark did you say you were replacing the diff bearings as well?
53ongoing build - Page 3 Empty Re: ongoing build on 4th July 2013, 7:00 pm
Yeah i saw that pete ...thanks it all helps get a good list together Wink
54ongoing build - Page 3 Empty Re: ongoing build on 4th July 2013, 7:04 pm
Yeah could do with a few more in there Rolling Eyes
55ongoing build - Page 3 Empty Re: ongoing build on 13th July 2013, 9:02 am
@pulsarmoley wrote:Put that company under the section. Mark did you say you were replacing the diff bearings as well?
Cheers for putting the link up mate, although not had a chance to touch the car this week.
Nah just the side oil seals I will be replacing
56ongoing build - Page 3 Empty Re: ongoing build on 3rd August 2013, 6:37 pm
well not really had much time for the pulsar over the last few weeks as had a few problems at home. However i finally pulled me finger out and got the grinder to work. So far cleaned up all the boot floor and above the fuel tank and no horror stories to be found. All in primer now so will give it a week to dry, make sure theres no reaction or spots ive missed and then get some coats of underseal on.
ongoing build - Page 3 IMG_20130803_155610-1
57ongoing build - Page 3 Empty Re: ongoing build on 3rd August 2013, 7:03 pm
Your doing well there fella Cool  Think after working on mine today I'm gonna have to give it a good going over Crying or Very sad
58ongoing build - Page 3 Empty Re: ongoing build on 3rd August 2013, 8:22 pm
fred05
fred05
french connection
french connection
Nice work buckym!
59ongoing build - Page 3 Empty Re: ongoing build on 3rd August 2013, 8:46 pm
not good mate, think every pulsar should come with a free welder and some sheet metal. so many water traps hidden away. Best to just bite the bullet strip it right down and see how bad it is.
Cheers Fred, taken a while but i'm slowly getting there. Once i've received my sub frame bushes from vss-irvine i can start rebuilding the sub frame
60ongoing build - Page 3 Empty Re: ongoing build on 14th August 2013, 4:11 pm
Well I had a little delivery from 3m last week so set about undersealing the car and getting closer to getting it rebuilt thanks to Pete getting hold of 2 diff seals for me.
ongoing build - Page 3 IMAG0707-1
ongoing build - Page 3 IMAG0711
61ongoing build - Page 3 Empty Re: ongoing build on 14th August 2013, 8:39 pm
jaypjay
jaypjay
Where do you get these diff seals from Wink
Very nice job on the underseal mate. Did you angle grind clean the bottom before painting ? Find any rust ?
62ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 10:36 am
looks very nice under there marky, you've done a great job so far
63ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 1:10 pm
mreguest
mreguest
some pictures of the tank and fuel lines replacement would be greatly appreciated when you get chance. very high on my list of things to do. i get a really strong smell of petrol inside and outside the rear of my car but there's no evidence of a leak underneath so i'm thinking the upper pipes are at fault.
it only smells strong with 3/4's to a full tank. around half tank does not smell at all - what the hell does that mean!?!?
cheers and good luck!
Adam
64ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 2:38 pm
Maybe the rubber seal on the top hasnt seated properly easy enough to take off and re do ...
65ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 9:33 pm
@jaypjay wrote:Where do you get these diff seals from Wink
Yes mate used my grinder and many wire brushes and I was amazed as to how clean it was where the fuel tank and sub frame sit. Bit of surface rust aroud the rear box section but no holes. I'm about to move forward to the middle section where exhaust and prop sit and I've found my first and only bit which will need to be plated underneath.
66ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 9:38 pm
Only picture I have mate of the tank at the moment
ongoing build - Page 3 IMAG0407
67ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 9:43 pm
jaypjay
jaypjay
Yes im currently working on the inside. I have rwmoved most of the sound deadening, wiring looms and now getting stuck into grinding it clean for a paint. I jad found 3 bad rust holes mostly around the foot wells and hidden by seal glue.
Is there any chance you could do a how to ? Even maybe a couple of pics.
Im scratching my head on the underseal. Dont know where to mount the stands to not damage it and removing the subframe are my biggest concerns and what choice of underseal/rust preventative.
Are you doing the fuel lines as well?
Thanks alot joel
68ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 10:04 pm
I sourced them locally for Mark.
69ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 10:09 pm
I've already replaced all the fuel pipe on the tank but dont have any pics mate, have hundreds of pictures of everything else, what pics/details are you looking for?
The only rust I've found inside the car is around the drivers rear strut turret (page2) which looks to be a common water trap.
With regards to underseal and primer I've used bilt hamber primer(Electrolux) and then 3m Shultz underseal and so far has gone really well together.
With the axel stands I've put mine on the rear box section with an oval hole as it was solid, just don't use the floor pan.
70ongoing build - Page 3 Empty Re: ongoing build on 15th August 2013, 10:51 pm
jaypjay
jaypjay
Thankyou for your info buck.
I will try and do a "how to" thread on this for members.
Moley are you able to get any more seals ?
Cheers
Joel
71ongoing build - Page 3 Empty Re: ongoing build on 16th August 2013, 11:34 am
mreguest
mreguest
Thanks for the picture! WTF!?!? how many pipes are on top of the tank!!! affraid
i thought there would be the 3 that run the length of the car to the engine + the filler neck Smile is that another fuel filter i see? (bottom middle of the picture?)
how much fuel pipe should I buy to redo all and what is the inner/outer dimensions of the pipe? did you find the clips were all re-useable?
bilt-hamber do dynax s50 which is good cavity treatment and the 60cm application lance is bloody brilliant, spray it in everywhere! look in the 'how to use' section in this link...
http://www.bilthamber.com/cavity-waxes/dynax-s50
72ongoing build - Page 3 Empty Re: ongoing build on 16th August 2013, 5:19 pm
@jaypjay wrote: Moley are you able to get any more seals ?
Cheers
Joel
Yes mate but as your down under I'm sure there would be a supplier a bit closer?
73ongoing build - Page 3 Empty Re: ongoing build on 26th August 2013, 1:51 am
jaypjay
jaypjay
Hey moley. Not that I'm aware of hey. I have been looking around with no luck.
74ongoing build - Page 3 Empty Re: ongoing build on 26th August 2013, 7:48 am
How about here:
http://www.ozseals.com/contact/
http://superseals.com.au/about.html
75ongoing build - Page 3 Empty Re: ongoing build on 26th August 2013, 7:53 am
jaypjay
jaypjay
Legend thank you
Back to top  Message [Page 3 of 7]
