Gtir Motorsport club » General Discusion » Gtir related Discussion » Forge auctuator
Forge auctuator
1Forge auctuator Empty Forge auctuator on Mon Apr 24, 2017 3:37 am
SonaGTIR
Guys. My car is running 0.9 bar making 286hp. Whilst having work done to the car I'm thinking of reppaveing my stock auctuator for a forge straight bar one I have. Would this mean I would have to remap or change the cars furlong/timing or anything over again? It's been lying in the house so I'm thinking it may aswell go on
2Forge auctuator Empty Re: Forge auctuator on Mon Apr 24, 2017 10:19 am
Daveymeladdy
Daveymeladdy
Bob has just changed my one for a Forge actuator. The standard one wasn't man enough to operate the waste gate at 1.3 bar. I got the spring kit as well, I think we put the blue spring in there as the pressures are not quite what forge quoted them at.
The car was put back on the dyno just to check fueling etc and then the boost controller was adjusted to the desired boost level as it performed different with the new actuator. I would recommend you get Bob or someone to check the fueling etc afterwards just so its boosting / fueling as it should.
