Gtir Motorsport club » Tech room » Help and Advice » Rev counter not working
1Rev counter not working  Empty Rev counter not working on 23rd April 2017, 5:11 pm
Another issue is my Rev counter wont work. Not at all just stopped ages ago.
I have a phase 2 set of clocks (said to be working but not tested myself) swapped the board on the back over as my clocks are phase 1 to the phase 2 set of clocks but the counter still doesnt work. Have cleaned all connectors etc.
How does the RPM signal work? Is there anything else I need to check in the engine bay etc.
It may be that I have two faulty sets of clocks but want to check if I can diagnose it further.
Thanks
2Rev counter not working  Empty Re: Rev counter not working on 23rd April 2017, 5:16 pm
Take a reading or pulse from the ecu. Think it's a grey wire. Cant quite remember tho lol
3Rev counter not working  Empty Re: Rev counter not working on 23rd April 2017, 5:48 pm
Rev counter not working  Ecu-pinout-1_zpscbq2tefy
Pin #
Name
Function
Signal Type
2
Tachometer Signal
Engine Speed Sensor Signal
Speed
4
Main Relay (Electronic Concentrated Control System)
12V Switched
Power
6
Power Ground (Electronic Concentrated Control System)
Chassis Ground
Ground
13
Chassis Ground
Ground
16
Mass Air Flow Sensor
Mass Air Flow Sensor Signal
Analog
17
Mass Air Flow Sensor Ground
Chassis Ground
Ground
18
Engine Coolant Temperature Sensor
Engine Coolant Temperature Sensor Signal
Analog
19
O2 Sensor Signal
Oxygen Sensor Signal
Analog
20
Throttle Position Sensor
Throttle Position Sensor Signal
Analog
21
Sensor Ground
Chassis Ground
Ground
26
Air Temperature Sensor
Air Temperature Sensor Signal
Analog
27
Knock Sensor
Knock Sensor Signal
Knock, Audio
29
Sensor Ground
Chassis Ground
Ground
32
Vehicle Speed Sensor
Vehicle Speed Sensor Signal
Speed
36
Ignition Switch
12V Switched
Power
39
Chassis Ground
Ground
46
Power Supply (Aux)
12V Permanent
Power
47
Power Supply (Engine Control Module)
12 Switched
Power
48
Chassis Ground
Ground
101
Injector # 1
Speed
103
Injector # 3
Speed
107
Chassis Ground
Ground
108
Chassis Ground
Ground
109
Power Supply (Aux)
12V Permanent
Power
110
Injector # 2
Speed
112
Injector # 4
Speed
116
Chassis Ground
Ground
4Rev counter not working  Empty Re: Rev counter not working on 23rd April 2017, 9:46 pm
Which one is it Stu?
Number 47 was severed so I have repaired the wire and also 32 was unplugged (it has a push connector)
Sorted all my loom out but still no joy with the rev counter. Which one would it feed from? Could someone wrecking my loom by trying to pull the safc wiring out cause an issue with my ecu itself with 47 been severed thats power to the engine control module which couldnt have been good!
5Rev counter not working  Empty Re: Rev counter not working on 24th April 2017, 7:06 am
Pin #2
