Gtir Motorsport club » General Discusion » Gtir related Discussion » emissions on mot
emissions on mot
1emissions on mot Empty emissions on mot on 24th April 2017, 3:35 pm
My car passed the mot today Smile
Every year my HC on emissions is really high.
Its at 2611 and it should be 1200 or less.
Mot tester said its un burnt fuel.
I have my dizzy set to 20°
Should I drop it back to 18°
A quick search on google and the site I went on said it was down to  ignition timing.
2611 to me says it's massively over fueling. But I have no idea if it is excessive or not?
The OC reading is really low. Its reading 0.16
Why would that be or what would cause that.
Max the OC should be 3.5 and he said normally cars are 1.5.
2emissions on mot Empty Re: emissions on mot on 24th April 2017, 7:06 pm
Is this not because you're running too rich?
3emissions on mot Empty Re: emissions on mot on 24th April 2017, 7:14 pm
@Cosmic73 wrote:Is this not because you're running too rich?
Yeah thats what im asking about Neil.
Its on standard ecu and the hks afr is disconnected. .
Just seeing if I should retard the ignition back to 18° or if it's okay to leave it at 20°
Would like to know what others HC readings are?
4emissions on mot Empty Re: emissions on mot on 24th April 2017, 7:18 pm
HC is result incomplete burning of fuel .
Due to CO being low it not over fueling but more case of not burning fully which could be timing related.
Kind of brings you back to your rough idle and doubts on cam timing being right !
5emissions on mot Empty Re: emissions on mot on 24th April 2017, 7:33 pm
@Mr B wrote:HC is result incomplete burning of fuel .
Thanks B Smile
I need to get my cam timing checked asap then.
Looks like I will be taking the cam cover off this weekend lol
6emissions on mot Empty Re: emissions on mot on 24th April 2017, 7:39 pm
Seems you got doubts on cam timing it best looked at as cures the doubt if nothing else .
I mark all my cam pulleys on rebuild with 2 lines on each which align to a straight edge as the factory setup is messy idea and easy get wrong unless do lot of them.
7emissions on mot Empty Re: emissions on mot on 24th April 2017, 7:55 pm
Yeah it will ease my mind if nothing else.
I have only done the cam timing 3 times now.
Will see the weekend if its out.
