Gtir Motorsport club » General Discusion » Gtir related Discussion » Oil Pump - What are the differences between the GTI-R and SR20VET units
As the title says, looking at what are the differences between the SR20DET and SR20VET oil pumps.
I know there is info on the different sizes of the pump cogs, the flow galleries and the pressure springs.
I have seen pictures that show the 2 side by side with all the info BUT I can't find it.
Any help and or pictures welcome.
Thanks in advance.
http://www.sr20-forum.com/forced-induction-mechanical/48901-best-stock-sr20-oil-pump.html
Is that what your after ?
@nomad wrote:http://www.sr20-forum.com/forced-induction-mechanical/48901-best-stock-sr20-oil-pump.html
Thanks for that, that is probably the site I was looking for.
BUT
Every time I go to access it even just putting in "www.sr20-forum.com" I get a RED screen with a message "DECEPTIVE SITE".
Did it load ok for you as it might be my firewall blocking it?
My internet security blocks the link aswell, malware by the looks
FPSChris
FPSChris
I'll save you a few clicks:
"So the differences are noticeable but considering how many 90* angles the oil has to pass through inside the block, the flow difference is negligible. Once the oil comes out of the pump it has to turn 90* 2" into the block in order to go through the oil filter housing and another 180* to get back into the block. Go ve pump when you can, but if you can't you prob won't notice a difference unless you are revving really really high."
Worked fine for me nothing dodgy well not that i noticed no pop up or anything...
