Gtir Motorsport club » General Discusion » Gtir related Discussion » Fuel pumps leaking
Fuel pumps leaking
1 Fuel pumps leaking on 5th May 2017, 8:17 am
Has anyone used 044 pumps?
Mine are leaking from the outlet. Should I be using an o-ring, crush washer or both? plus sealant?
Ive read contradicting things online, so thought Id ask Smile
2 Re: Fuel pumps leaking on 5th May 2017, 11:46 am
Crush washer only. It's a metric thread not ORB so no O.ring
You should also be using a check valve on the outlet of each pump as there is no internal one. If you stage the pumps fuel will flow backwards through the 2ND pump without a check valve.
3 Re: Fuel pumps leaking on 6th May 2017, 4:29 am
Thanks mate.
4 Re: Fuel pumps leaking on 25th June 2017, 8:17 am
So originally I used crush washers, so I thought id replace them, still leaked.
Tried different OD crush washers and still leaked.
Used 2 washers per fitting and think its solved the problem.
Pretty much high on petrol fumes after that Laughing
