Gtir Motorsport club » Tech room » Help and Advice » Help on engine please
26Help on engine please - Page 2 Empty Re: Help on engine please on 28th May 2017, 8:25 pm
Not really you will have to check block pistons and liners for wear but crank and big end shells .... cranks are the worst if not salvagable ....
27Help on engine please - Page 2 Empty Re: Help on engine please on 28th May 2017, 8:29 pm
Crank is harder to source a block should be easy if you did need one
28Help on engine please - Page 2 Empty Re: Help on engine please on 19th June 2017, 11:59 am
Telly
Sorry not posted with a update. Just want to say thank you to Stu for all the help sorry buddy for all the newbie questions.
So update....... the engine is completely gone and needs a full engine rebuild as head gasket has gone. I tool the sump off and found water mixed with with oil :-(
29Help on engine please - Page 2 Empty Re: Help on engine please on 19th June 2017, 9:31 pm
Happy to help mate.
Sorry to hear the engine is fucked Sad
30Help on engine please - Page 2 Empty Re: Help on engine please on 20th June 2017, 10:49 am
Telly
Atleast now i can start to rebuild the engine to spec i want all at once instead of doing it one thing at a time.
Just hope i dont fk everything up tryna rebuild as i have no clue lol
31Help on engine please - Page 2 Empty Re: Help on engine please on 1st July 2017, 9:29 pm
Telly
Hi guys. So i am trying to take the upper oil pan off but its just not happening if taken all the bolts i can see but its not coming off am i missing something? I have searched everything but no luck can any 1 help plz
32Help on engine please - Page 2 Empty Re: Help on engine please on 2nd July 2017, 6:40 am
How many have you found/removed
33Help on engine please - Page 2 Empty Re: Help on engine please on 2nd July 2017, 7:24 am
Spark plug spike
Spark plug spike
Have you used the 2 x engine to transaxle bolts as per below mate?
Help on engine please - Page 2 Image10
34Help on engine please - Page 2 Empty Re: Help on engine please on 2nd July 2017, 8:16 am
I would say without a doubt that's bottom end growl .
35Help on engine please - Page 2 Empty Re: Help on engine please on 2nd July 2017, 12:16 pm
Telly
Hi spike thanx no i have not done that i am going to try that now thank you. I have removed apl the other bolts just not fitted the 2 into the vacant holes
36Help on engine please - Page 2 Empty Re: Help on engine please on 3rd July 2017, 8:56 pm
Telly
Hey guys thank you managed to get it off in the end very confusing for some one who has never worked on a engone before lol thanx guys gna tale crank n bearing out next and top head.
