Gtir Motorsport club » Tech room » Help and Advice » headliner
headliner
1 headliner on 28th May 2017, 3:35 pm
92pulsar
92pulsar
need some help on getting my head liner off. how hard is it and how much on the interior do i have to take off
thanks from Canada
David
2 Re: headliner on 28th May 2017, 4:54 pm
The rear metal trim. Caps and 2or 3 screws for that. Rear view mirror clip cap off think it's 3 screws and base plate might need to come off. The few clips you can see down each side. A pillar trims just clip out at top ( if removing fully bottom slides up not just out or it will snap clip ) . Center light cover clips off with flat head/bladed screw driver couple screws and wire connection you will see as you lower it will then press and un clip. Top of my head can not remeber about  center pillars but if you do it's clip covers off seat belts two prob 14mm bolts slacken or remove fully if required. Keep washers etc in order.If they do  DONT let sealtbelts coil to far back.
Sounds a lot but really not to bad bring it out through boot and a second person to help feed it out will certainly help. Why is it been removed ?
3 Re: headliner on 28th May 2017, 6:37 pm
92pulsar
92pulsar
good ole rattling roof braces
4 Re: headliner on 28th May 2017, 7:37 pm
Daveymeladdy
Daveymeladdy
As Johnny said, it's not too bad. I once took it all down in order to change the sunroof glass before finding out that I can do it without removing the head lining duh
5 Re: headliner on 28th May 2017, 7:57 pm
Yep had a feeling. Just going to squirt some sealer behind ? Do yourself s favour drive it for a week before you refit it make sure it's sorted
6 Re: headliner on 28th May 2017, 9:12 pm
92pulsar
92pulsar
yeah just going to put some sealer in. thanks for the advise Johnny
7 Re: headliner on 28th May 2017, 9:47 pm
No problem anytime.Normally a few on here to advise. It's simple but like anything unless you have done it before it can be the difference between snapping a clip or similar and not so any questions ask away
8 Re: headliner on 28th May 2017, 10:47 pm
We all got to start somewhere its always a learning curve no matter how long you have been doing it as im sure most will agree so no question is bad or frowned upon Wink
