Gtir Motorsport club » Tech room » Help and Advice » front brake pads
front brake pads
1 front brake pads on 3rd June 2017, 9:53 pm
92pulsar
92pulsar
will front brake pads from 91 sentra fit and also will the same rotors fit
2 Re: front brake pads on 3rd June 2017, 11:30 pm
b13 sentra se has same discs not sure on pads, I know the 100nx is same on disc/pad .nx2000 also
double check sizes before commit to anything though .
3 Re: front brake pads on 4th June 2017, 10:34 am
Why not just buy ones which will fit? Standard pads are very cheap.
4 Re: front brake pads on 4th June 2017, 10:58 am
I'm assuming because he in usa or canada and have no easy/sensible price option for n14 parts ...
5 Re: front brake pads on 4th June 2017, 12:52 pm
That would make sense didnt see any location on his profile. Good luck finding something!
6 Re: front brake pads on 4th June 2017, 3:17 pm
92pulsar
92pulsar
Yeah im out in Canada
7 Re: front brake pads on 4th June 2017, 6:59 pm
Here's some dimensions and part numbers that may help you cross check the part in maple syrup country . should be quite easy once look into it, good luck .
pad set:
Nissan p/n 4106054C87
Brake System: AKB
Width: 127.8 mm
Height: 51.7 mm
Thickness: 15 mm
direct cross part numbers http://www.autopartoo.com/oem/partscrossinterchange/4106054C87
disc:
nissan p/n 4020654C01
Height: 45.5 mm
Diameter: 257 mm
Centering Diameter: 61 mm
Pitch Circle Diameter: 100 mm
Brake Disc Thickness: 26.0 mm
Minimum Thickness: 24 mm
Num. of holes: 4 (4x100)
Vented: yes
direct cross part numbers http://www.autopartoo.com/oem/partscrossinterchange/4020654C01
