Gtir Motorsport club » Gallery » Members gti-r's » Tarmac Rally Car
Tarmac Rally Car
1Tarmac Rally Car Empty Tarmac Rally Car on 4th June 2017, 5:01 am
velly4
velly4
I thought it was time that we started this for the Tarmac Rally Car.
At this stage, it's very very early days and there hasn't been a whole lot of work done on the actual car but plenty is going on behind the scenes.
The plan is to use the running gear out of my other R with a few bits and pieces off a fellow members car to allow us to comply with Targa Tasmania Regulations.
Currently we are in the process of working out what brakes, wheels, and suspension we are going to run. Will most likely be a set of Team Dynamic Pro-race 1.2 15x8 wheels, 300mm x 32mm 2 piece rotors with Alcon calipers and hopefully MCA coilovers (which could be good for other owners).
The GTiR falls into the Early Modern class which takes in all cars built from 1st January 1986 to 31st December 2007.
Within Early modern its broken into 2 categories, Category 7 (1986 - 1999) and Category 8 (2000 - 2007).
Each category is then broken into 4 classes:
Class A - Up to 2500cc
Class B - 2501cc to 3500cc
Class C - 3501cc to 4500cc
Class D - Over 4500cc
Rules for modifications also varies depending on the cars performance level in standard form.
The 3 levels are SS which allows very little modification (Corvettes, Vipers, Porsche, Honda NSX for example)
LMS allows for slightly more mods and all Evos, WRX and Skylines fall under this level
MS is where our girl falls under allowing us the most freedoms.
Even though we have the most freedoms, the modifications I've made, have to be wound back a little bit, mainly the turbo.
We are planning on going back to a top mount intercooler for simplicity and efficiency. Less chance of pipes blowing off or being damaged, better airflow to the radiator and oil cooler.
We are trying to keep everything as simple, basic, easy to work on, easy to replace as much as we possibly can.
For more regular updates and post please check out our Instagram and Facebook page. Every like and follow helps us when it comes time to find sponsorship.
www.facebook.com/YoriMotorsports/
www.instagram.com/yori_motorsports/
(50 Kb) Downloaded 9 times
2Tarmac Rally Car Empty Re: Tarmac Rally Car on 4th June 2017, 5:02 am
velly4
velly4
(50 Kb) Downloaded 12 times
3Tarmac Rally Car Empty Re: Tarmac Rally Car on 4th June 2017, 5:02 am
velly4
velly4
(59 Kb) Downloaded 5 times
4Tarmac Rally Car Empty Re: Tarmac Rally Car on 4th June 2017, 5:03 am
velly4
velly4
(66 Kb) Downloaded 10 times
5Tarmac Rally Car Empty Re: Tarmac Rally Car on 18th June 2017, 9:43 am
Tarmac Rally Car A_Pillar_small_1
6Tarmac Rally Car Empty Re: Tarmac Rally Car on 18th June 2017, 9:43 am
Tarmac Rally Car B_Pillar_Small
7Tarmac Rally Car Empty Re: Tarmac Rally Car on 18th June 2017, 9:44 am
Tarmac Rally Car Cage_small
8Tarmac Rally Car Empty Re: Tarmac Rally Car on 18th June 2017, 9:45 am
Tarmac Rally Car Yori_2
9Tarmac Rally Car Empty Re: Tarmac Rally Car on 18th June 2017, 9:47 am
Posted direct links of the pics mate, looking forward to watching the progress on this thumbsup
10Tarmac Rally Car Empty Re: Tarmac Rally Car on 18th June 2017, 10:57 am
Thats a work of art..
Look forward to the updates too Smile
