Gtir Motorsport club » Tech room » Help and Advice » Braided oil feed hose
1Braided oil feed hose Empty Braided oil feed hose on 7th June 2017, 7:58 am
Hey guys,
I'm just finishing building my exhaust fannymold and turbo assembly to go back on but I'm not sure about the routing of the replacement oil feed hose. It looks like the engine banjo connection will line up ok but the hose itself looks like it'll be touching the block ( see attached  pic).
 Is this right or does the hose go round the front of the turbo? Should I wrap something around the hose (PTFE tape?) to stop it damaging the hose? Should I just bolt it up and stop worrying about it as the turbo and engine won't move relative to each other?
 Cheers guys Very Happy
(81 Kb) Downloaded 11 times
2Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 10:45 am
could pad it with a piece of hose cut to wrap round it our perhaps small bracket with P-clip to hold it if accessible enough ... probably not going be much issue quickly if was touching but seen a few braided hoses wear through the braiding easier than you would think so tend go belt and braces to save any drama and wallet opening down the road ...
3Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 11:33 am
Cool, so its routed ok and this is normal. That's what I was worried about Mr B, the hose rubbing through due to vibrations and dumping oil everywhere. I don't think I've got a P-clip that size but I DO have plenty of silicone tubing I could wrap around it.
muchas gracias amigo Smile
4Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 5:18 pm
@mike74 wrote: I don't think I've got a P-clip that size
Make one out of a thin metal strip and drill a hole through job jobbied and no rubbing issues
5Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 7:23 pm
Gtirchris
If you're worried about it rubbing you can put some firesleeve over it and hold it in place with some lockwire, you can get the firesleeve from Motorsport retailers like Demon Tweeks or eBay probably
6Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 8:25 pm
I've wrapped a few of my turbo lines, helps with rubbing and there's a lot of heat here.
7Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 9:05 pm
Panic over...the new oil hose didn't f'kin fit!! When I attached one end to the turbo the engine end was about 45 degrees out. If access was good I could've made it fit but behind or on top of the turbo, forget it. I ended up cleaning out the original hatd pipe as best I could and refitted that.
But on a more serious note, when nissan were building these cars did they suspend the bloody turbo on a bit of wire and build the rest of the car around it??
8Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 9:39 pm
Only way I do turbo house or any pressure/hydraulic lines these days is custom made via local hydraulic line shop or buy push fittings (expensive) and hose to do it yourself .
Anything pre made is over-priced and always poor fit one way or other (too long/short, fittings not clocked to best position or not ideal fitting type used)
9Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 10:53 pm
I made all my hoses using AN fittings. Its more expensive but you get to trial fit and make sure its exactly how you want it. Also the fittings are reusable, so if you change things its easier to adapt the hoses.
10Braided oil feed hose Empty Re: Braided oil feed hose on 7th June 2017, 11:43 pm
Best way woody really, I do a mock fitting then make it with push fitting or crimp via local shop who good at clocking them as marked on pipe supplied .
Reusable fittings are handy but as I got hydraulic line shop 2km up road open 6 days a week which is so cheap/reliable it what generally do these days.
