Gtir Motorsport club » General Discusion » Gtir related Discussion » ABS Light wiring
ABS Light wiring
1ABS Light wiring Empty ABS Light wiring on 11th June 2017, 1:23 am
Hey guys
Question about wiring my ABS light for my digital dash install.
Based on the below diagram the ABS light is pin 31 & 32
Pin 32 goes to the ABS control and Pin 31 to ignition, does this mean the light is triggered by a switched ground in the ABS control unit? Am I reading that right?
ABS Light wiring New
2ABS Light wiring Empty Re: ABS Light wiring on 11th June 2017, 7:49 am
Can prob get you the colour of the wire. Where you planning on taking the supply from mate ?
3ABS Light wiring Empty Re: ABS Light wiring on 11th June 2017, 8:26 am
Ill just take power from pin 31 and ground side of the light to pin 32. I just wanted to make I was reading the diagram right.
4ABS Light wiring Empty Re: ABS Light wiring on 11th June 2017, 8:40 am
Yep, that looks right to me.
5ABS Light wiring Empty Re: ABS Light wiring on 11th June 2017, 8:21 pm
Cheers mate, I'll test it this arvo.
6ABS Light wiring Empty Re: ABS Light wiring on 12th June 2017, 10:10 am
Use the red light for a shift light using the haltech
