Gtir Motorsport club » Tech room » Help and Advice » ecu
ecu
1 ecu on 4th July 2017, 5:19 pm
92pulsar
92pulsar
NOOB question have mines ecu in my R found this info online
1.1bar, 500 extra rpms, removed speed limiter, and modified fuel and ignition tables
so heres the question is my R running these specs
2 Re: ecu on 4th July 2017, 7:35 pm
Yes the limit is raised
But you need to check boost
Do you have uprated fuel pump ?
Ignition system needs to be in good condition and those maps are quite aggressive but run a lot of ignition and I personally would get it checked if it's long term Ecu you plan to run
3 Re: ecu on 4th July 2017, 7:39 pm
92pulsar
92pulsar
its the way i got it about 8 years ago havnt checked fuel pump i find at mid rpms the car picks up and goes like a bat out of hell no bogging or anything How can i check boost?
4 Re: ecu on 4th July 2017, 7:40 pm
Boost gauge. Standard one won't read above 7 psi tho
5 Re: ecu on 4th July 2017, 7:44 pm
92pulsar
92pulsar
yeah i only have stock gauge
6 Re: ecu on 4th July 2017, 7:56 pm
Always worth investing in one .... and a wideband Wink
7 Re: ecu on 4th July 2017, 8:51 pm
92pulsar
92pulsar
what the best one to get
8 Re: ecu on 4th July 2017, 10:34 pm
Wich one mate the wideband or boost gauge ?
9 Re: ecu on 4th July 2017, 10:35 pm
92pulsar
92pulsar
Both
10 Re: ecu on 5th July 2017, 8:06 pm
Spoilt for choice on boost gauges really it comes down to personal preference as for wide band I have a aem but yet again personal preference really I bought a cheap boost gauge was a waste of money as the needle gets stuck duh
11 Re: ecu on 5th July 2017, 8:36 pm
92pulsar
92pulsar
So i should go with mechanical not digital
12 Re: ecu on 5th July 2017, 9:47 pm
Yeah I have a TIM boost gauge not fancy but does the job
13 Re: ecu on 6th July 2017, 7:51 pm
Stack are very good do simple ones that req no power or electronic ones also do wide bands
As above aem or innovate do one
