Gtir Motorsport club » General Discusion » Gtir related Discussion » cheap manifold gaskets
1 cheap manifold gaskets on 24th July 2017, 10:02 pm
I needed to buy a manifold to turbo gasket the other week.
Searched ebay and found one with the head to manifold gasket included for a cheap price.
So thought while it was all off I would change that one too.
Wish I fucking hadn't lol
The old gasket wasn't leaking so didnt need changing.
Put the new one on and I had a leak right away.
Couldnt be arsed to swap it back so left it.
Wasnt driving the car much so lived with it.
But each drive it got worse.
Decided tonight to take it off and put the multi layered metal gasket back on.
This is what I took off.
Fucking cheap piece of shite!!!
2 Re: cheap manifold gaskets on 24th July 2017, 10:05 pm
Don't always pay to go cheap was it not amother multi layer gasket ?
Was there meant to be a pic?
3 Re: cheap manifold gaskets on 24th July 2017, 10:08 pm
Pic now added mate.
My photobucket links aren't working for some reason.
The cheap one isn't metal I do t think?
It is layered tho. Its already started to seperate.
4 Re: cheap manifold gaskets on 24th July 2017, 10:09 pm
Pic is working now ..... that's some serious amount of leaking going on .... do you never paste gaskets as well ? I always put a light coat on each side to take out any imperfections ...
5 Re: cheap manifold gaskets on 24th July 2017, 10:21 pm
No I have never added a paste to the manifold gasket.
Never thought about it.
I will do that if it leaks again Smile
6 Re: cheap manifold gaskets on 24th July 2017, 10:22 pm
It was leaking on all 4 ports ffs lol
7 Re: cheap manifold gaskets on 25th July 2017, 3:55 am
Piece of shit, I've never used sealant and been fine.
8 Re: cheap manifold gaskets on 25th July 2017, 6:17 am
Those type gaskets are nasty slightly better if they have the solid pressed rings around the inner but always use a quality multi metal for manifold and single metal on turbo both sides.which means I never req sealer or paste and it's fine. You still using a stainless mani Stu ? If so it certainly won't of helped with the gasket type you used
9 Re: cheap manifold gaskets on 25th July 2017, 7:49 am
I've got very similar looking gaskets fitted to my fannymold...and turbo-fannymold and also the downpipe. They're not leaking so far but you've got me worried now Crying or Very sad
10 Re: cheap manifold gaskets on 25th July 2017, 10:05 am
danno
I hate them gaskets, they nearly always blow no matter where you use them on the exhaust. I've just replaced all the gaskets on mine but used a genuine nissan manifold one and the turbo ones were metal ones from ID workz, they're all good so far.
11 Re: cheap manifold gaskets on 25th July 2017, 1:12 pm
@johnny gtir wrote:Those type gaskets are nasty slightly better if they have the solid pressed rings around the inner but always use a quality multi metal for manifold and single metal on turbo both sides.which means I never req sealer or paste and it's fine. You still using a stainless mani Stu ? If so it certainly won't of helped with the gasket type you used
Yeah still got the dp manifold on Johnny.
I put the multi layered metal gasket back on and been out hooning it around and all is good again Smile
I won't be buying cheap again that's for sure lol
12 Re: cheap manifold gaskets on 25th July 2017, 5:11 pm
Haha I habe had the same multi layer hasket for 8 years now never blown, those things are cack.
Its a sharp learrning curve I have also done with the turbo elbow didnt tighten up my bolts enough or use spring washers so it all came loose and had to take whole turbo off to sort it
