Gtir Motorsport club » General Discusion » Gtir related Discussion » Fuel missfire
Fuel missfire
1Fuel missfire Empty Fuel missfire on 3rd August 2017, 1:28 pm
Zia
Got my gtir taxed and insured.but having a massive missfire at idle.running and sounding like a scooby.
No 4 cylindar is not running properly.sparking ok but no fuel going in.checked the injector works ok.even swapped with known good one.
On further investigation getting 12v too all injector both side of the harness plug no 1 2 3 on white coloured wires are being switched to ground and working fine.
But no 4 is not grounding properly.have done continuty test and from resistor pack to injector wire is fine. Any help would appreciated
Thanks zia
2Fuel missfire Empty Re: Fuel missfire on 3rd August 2017, 6:18 pm
Totally guess Ecu related then. What Ecu did you say you were running or changing mate ?
3Fuel missfire Empty Re: Fuel missfire on 3rd August 2017, 6:22 pm
Yeah if I'm nit mistaken injector earth is controlled by ecu. Check you wiring from ecu to injector first before bining ecu...
4Fuel missfire Empty Re: Fuel missfire on 3rd August 2017, 8:02 pm
Zia
Totally guess Ecu related then. What Ecu did you say you were running or changing mate ? wrote:
Standard with motec m4 pro in piggyback mode.motec does all the fueling,ign and some additional sensors,all other sensor go to stock ecu.
Worse come to worse i do have stock ecu and i could swap over
Zia
