Gtir Motorsport club » Tech room » Help and Advice » Speedo this time
Speedo this time
1Speedo this time Empty Speedo this time on 22nd August 2017, 8:08 am
Keensie
So I've fixed one problem now another one comes up,Speedo is dead all other gauges are working where's the best place to start to solve this?I seem to be doing more fixing than driving these days.
2Speedo this time Empty Re: Speedo this time on 22nd August 2017, 8:13 am
Does it have a kmh to mph convertor/delimiter chip installed? That would be my first port of call if it does. They can fail sometimes or you might luck out and just have to fix a crimped connection somewhere Smile
3Speedo this time Empty Re: Speedo this time on 22nd August 2017, 11:15 am
As mike says speedo converter good place start .
Is known for diode or solder issues on the clock board too so visual inspection may help .
check speedo signal to ecu if got consult software and from sensor/to clocks, can use a LED if not got test meter etc .
4Speedo this time Empty Re: Speedo this time on 22nd August 2017, 2:12 pm
Keensie
Thanks yes it has a converter so that's my first check.
One other question I don't have heated seats but I have a fuse and live going to the fuse according to the diagram would this be for something else?
5Speedo this time Empty Re: Speedo this time on 22nd August 2017, 2:56 pm
Could well be...pull it out and see what stops working Very Happy
6Speedo this time Empty Re: Speedo this time on 13th September 2017, 7:35 pm
Keensie
So I've found the converter but if it was broken would this cause the car to be limited? It still revs and drives as normal.
7Speedo this time Empty Re: Speedo this time on 14th September 2017, 6:09 am
It will it limits the speed not the revs mate. 112mph limiter
8Speedo this time Empty Re: Speedo this time on 14th September 2017, 9:33 am
You could try and reconnect the original wiring and remove the delimiter to see if everything starts to work ok. Re-connect them with crimps so you can plug the delimiter back in afterwards.
FWIW this is the delimiter I've got installed in my motor and works fine Smile
http://www.ebay.co.uk/itm/NISSAN-300ZX-PULSAR-SKYLINE-SPEEDO-CONVERTER-DELIMITER-SPEEDOMETER-CONVERSION-/120446038718?hash=item1c0b24b2beⓂmUs6XY_BzzKtZ2x2ULrOfkA
9Speedo this time Empty Re: Speedo this time on 14th September 2017, 10:09 am
As B said, I would be checking to see if ECU is getting a signal before going to the effort of mucking with the converter
10Speedo this time Empty Re: Speedo this time on 14th September 2017, 4:00 pm
Keensie
i've removed the converter no difference how do i check the signal to ecu without getting too technical?don't want to remove the speed sensor as it lokks a pig to remove.
11Speedo this time Empty Re: Speedo this time on 14th September 2017, 8:57 pm
12Speedo this time Empty Re: Speedo this time on 14th September 2017, 9:01 pm
13Speedo this time Empty Re: Speedo this time on 14th September 2017, 9:10 pm
Forget if this is carried on from a previous thread is the speedo plug in in bay and have you tried a different set of clocks ?
14Speedo this time Empty Re: Speedo this time on 14th September 2017, 10:20 pm
Check fault codes and if got consult cable very easy check speed signal at ecu .
For sensor test power and ground and use multimeter on AC Volts to test voltage across disconnected harness plug from sensor, should see around half a volt plus. I run in gear on lift/stands rather than pull sensor and spin it .
15Speedo this time Empty Re: Speedo this time on 15th September 2017, 9:13 am
Keensie
Thanks for the info it gives me something to work to.
16Speedo this time Empty Re: Speedo this time on 18th September 2017, 3:42 pm
Keensie
It's working! but according to my Sat nav 20 mph on the dials is 30mph on the Sat nav, it's always been this way and no difference with the converter wired in.
17Speedo this time Empty Re: Speedo this time on 18th September 2017, 6:37 pm
Sounds like the converter is not working or wired in wrong orbits only a delimiting one
18Speedo this time Empty Re: Speedo this time on 19th September 2017, 8:06 am
As johnny says.
I have a hks speed cut defencer on mine and a mph converter.
The hks speed cut doesn't convert the kph to mph.
19Speedo this time Empty Re: Speedo this time on 19th September 2017, 9:02 am
pfffftt who needs MPH Laughing
20Speedo this time Empty Re: Speedo this time on 19th September 2017, 5:01 pm
Keensie
I've removed the converter no difference, could I just take the needle off drive at 30 with Sat nav and push it back on?
21Speedo this time Empty Re: Speedo this time on 19th September 2017, 6:16 pm
Removed it ? Any pictures of it or how it's wired ? If it's in wrong or not working it won't make any difference fitted or not. Guess your not concerned about top end speed ?
Dose it not convert it all the way so say you done that at 30 would it not read out again by say 50-60 I don't know just putting it out there
22Speedo this time Empty Re: Speedo this time on 19th September 2017, 7:38 pm
Think you would be hard pushed to place the needle on at 30mph while driving to be honest
