Gtir Motorsport club » General Discusion » Gtir related Discussion » Arches
Arches
1 Arches on 26th August 2017, 8:19 am
kevmc76
kevmc76
Hi everyone was looking to fit arches to my pulsar as I think it's probably the best option due to the dredded rust taking a hold of mine so it I would appreciate help and pointed in the right direction for ones fellow Gtir owners have used.
Cheers
Kevin
2 Re: Arches on 26th August 2017, 12:00 pm
As in arch extension/trims or metal repair arch panels !
repair arches are done from the 5door panels which cheap but does need quality job last well plus means quarter respray or full respray .
is a link on repair panels and odd thread, cosmic recently done his.
few threads on arch extensions too .
http://www.carz2.co.uk/nissan-sunny-n14-sedhb-91-95-16450-c.asp
http://www.gtir-motorsport-club.com/t4686-sills-and-arches
partypete got interesting arch trim extensions.
sure some others can advise on it once know more on what you deciding to achieve with arches .
* would advise you change your avatar, took my mind right off job I was on and will be horny until mrs B turns up ... hopefully sight of her will put my mind back to task I was on .
3 Re: Arches on 26th August 2017, 5:35 pm
kevmc76
kevmc76
Thanks that is something to consider at that price too is amazing, haha you like the avatar
4 Re: Arches on 26th August 2017, 8:28 pm
What is it you need to know?
5 Re: Arches on 26th August 2017, 9:01 pm
what arch extension mould trims did you use on yours pete .
did the have any options on depth ?
kind of asking for my self now ...
6 Re: Arches on 26th August 2017, 9:49 pm
Depth wise there's a fare few options, when I WEnt to measure the arch gap from front to back (if that makes sense)? That was the hard part as it seems to be a hard size to find, but obviously I found one in the end after a lot of searching. Can't for the life of me remember who I got them off. But I had to cut out/trim/ re weld my arches to allow it all to work, wasn't an easy task
7 Re: Arches on 26th August 2017, 9:52 pm
Did you cut back inner arch on rear pete .
8 Re: Arches on 27th August 2017, 7:29 am
I sure did
