Gtir Motorsport club » Tech room » Help and Advice » help for blakeA
help for blakeA
1 help for blakeA on 27th August 2017, 10:58 am
Posting this for a new member Blake .....
https://youtu.be/17smuQSeRnQ
2 Re: help for blakeA on 27th August 2017, 10:59 am
Wants some advice on what the noise is.... sounds top end rattle to me ..... shims .. chain rattle.... noise injectors ...hard to tell from a video .
3 Re: help for blakeA on 27th August 2017, 2:34 pm
markface
Do you know if this developed after a rebuild or some other work or got worse over time?? Other than the noise does it still drive OK?
Other than suggesting some obscure bracket or bolt is loose and vibrating, exactly what you have already mentioned- i'd check chain tension and shim clearance. The injectors in all r''s I've owned had a loud injector tick but I think this sounds a bit more than that
4 Re: help for blakeA on 27th August 2017, 9:08 pm
BlakeA
Hi thanks for the reply it has had it ever since I have owned it. But it's getting to me at the moment. Doesn't affect the performance of it at all and still drives perfect like the day I bought it. I would say the motor has been rebuilt at one stage as the compression across all 4 cylinders is at 170psi.
5 Re: help for blakeA on 27th August 2017, 9:50 pm
Very very difficult to say as sounds like multiple issues tbh
We just sorted out an engine for someone (which came in for shimming) yet ended up being incorrect titanium valve springs and retainers coupled with incorrect Jun cams which were meant for sr20de with hydraulic lifters.
This causes a lot of valve train noise due to the rate the cams come off their profile & the extra tensile springs cause the valve to slam into the seat and vibrate.
Not suggesting thats whats wrong with yours but removing both the sump pan to access the oil pickup to check for obstructions and also the rocker cover to assess clearances and isdues is the first place to start
6 Re: help for blakeA on 27th August 2017, 9:55 pm
BlakeA
Thank you I will take the rocker cover off today. Is there a guide of how to check the shims
7 Re: help for blakeA on 27th August 2017, 11:06 pm
https://www.youtube.com/watch?v=lastgWJ4Ooo
Enjoy! lol!
8 Re: help for blakeA on 28th August 2017, 7:29 am
Thats an awesome vid thumbsup
9 Re: help for blakeA on 28th August 2017, 9:09 am
That's how I do them... After 4 of them it doesn't take that long anymore lol!
