Gtir Motorsport club » Tech room » Help and Advice » boost gauge
boost gauge
1boost gauge Empty boost gauge on 7th September 2017, 8:39 pm
92pulsar
92pulsar
Where do i T in pipe for mechanical boost gauge
2boost gauge Empty Re: boost gauge on 7th September 2017, 9:28 pm
I've got mine t piece onto the boost sensor ....
3boost gauge Empty Re: boost gauge on 7th September 2017, 9:34 pm
92pulsar
92pulsar
Do u have a pic where is boost sensor
4boost gauge Empty Re: boost gauge on 7th September 2017, 9:37 pm
It's located on the right hand side inner wing it comes across and has a single pipe that goes on it underneath ... that's where I have nine plumbed in others may differ
5boost gauge Empty Re: boost gauge on 7th September 2017, 9:39 pm
92pulsar
92pulsar
Ok thank you
6boost gauge Empty Re: boost gauge on 7th September 2017, 9:40 pm
Daveymeladdy
Daveymeladdy
T off the factory boost sensor as already suggested. Getting the pipe through the bulkhead is the fun bit!
7boost gauge Empty Re: boost gauge on 7th September 2017, 9:55 pm
92pulsar
92pulsar
Is it ok to leave the stock one hooked up with an aftermarket one
8boost gauge Empty Re: boost gauge on 7th September 2017, 10:00 pm
I have mine ... depends where you want to locate it you can obviously replace the stock one or dash mount it or pillar pod .... yeah it's tight I got mine through above the abs pump took a bit of feeding through as run my battery to boot cables .... if you have air con removed you can run it through where the pipes are or used to be on the bulk head
9boost gauge Empty Re: boost gauge on 7th September 2017, 11:26 pm
Its on left hand inner wing lol
Old trick for pulling wires and small pipes through
Get a bit of stiff wire ( like mig wire or similar)
Poke that through the hole then hook the bit of wire or pipe you want to pull through into the mig wire then pull the mig wire back through then hey presto your bit of wire / pipe comes through with it Smile
10boost gauge Empty Re: boost gauge on 8th September 2017, 1:19 am
92pulsar
92pulsar
is this what im looking for
(58 Kb) Downloaded 14 times
11boost gauge Empty Re: boost gauge on 8th September 2017, 5:43 am
Yes that's the one
12boost gauge Empty Re: boost gauge on 8th September 2017, 8:01 am
I routed mine through the big grommet behind the driver side wheel arch liner. The wires+vacuum tube comes into the cabin just above the throttle pedal which makes it easy to route up the side of the dashboard and then in behind the door rubber at the upper end Smile
13boost gauge Empty Re: boost gauge on 8th September 2017, 8:37 am
It's the right if your standing outside in the engine bay .. Laughing I should of just said passenger wing so there was no confusion duh
14boost gauge Empty Re: boost gauge on 8th September 2017, 9:33 am
Can also take it off a vacuum line on the inlet manifold, and save running longer tube through the engine bay. As mike said the grommet behind the driver side wheel arch is also good when mounting the gauge on the pillar aswell.
15boost gauge Empty Re: boost gauge on 8th September 2017, 6:27 pm
Sometimes they read slightly wrong there Woody and they also flutter abit when there mate
Like always my wording might not be 100% but you get the just of it
16boost gauge Empty Re: boost gauge on 8th September 2017, 6:35 pm
[quote="nomad"]It's the right if your standing outside in the engine bay .. Laughing I should of just said passenger wing so there was no confusion duh
I knew where it is but I also call it the right hand side as most stuff in the engine bay you describe standing or kneeling praying from the front looking in with bonnet up
So don't beat yourself up because we can always do that for you mate lol
17boost gauge Empty Re: boost gauge on 8th September 2017, 7:51 pm
What I usually do I throw away evap - carbon canister (you don't need it only makes mess) and use one of those pipes going to manifold for gauge and the other one for boost controller (if you've got one).
I absolutely hate when I see 3 t pieces from one 3mm vacc pipe.... Another thing when adding wires etc next to grommet for ecu there is another one for draining water from aircon evaporator, I'm guessing you haven't got your ac anymore you can poke small pipe through there if you want anything bigger (like battery lead when moving battery in to boot) you can actually take glove box out and then there is just few screws holding box with evaporator grind off that little drain thingy which goes in to bulkhead to make bit more room and route pipes wires etc through there....
Wow I've made a guide lol! lol!
18boost gauge Empty Re: boost gauge on 9th September 2017, 1:19 am
92pulsar
92pulsar
so got gauge installed looks pretty good
question my stock gauge is going right up to 700 mmhg almost 14 psi but new gauge is going up to 9 psi where do i start also noticed t that came with gauge has a restrictor is that right????
(57 Kb) Downloaded 21 times
19boost gauge Empty Re: boost gauge on 9th September 2017, 7:01 am
If it's half decent I guess your new gauge is reading accurate hence why we fit them soon as you up boost abit the standard one at 20 year old is prob as you say going right over
20boost gauge Empty Re: boost gauge on 9th September 2017, 7:04 am
Looks smart mate Wink
21boost gauge Empty Re: boost gauge on 9th September 2017, 7:28 am
The gauge actually looks really tidy there, nice install.
22boost gauge Empty Re: boost gauge on 9th September 2017, 9:02 am
*agree* looks good mate!
