Gtir Motorsport club » Tech room » Help and Advice » Carbon Cannister
Carbon Cannister
1 Carbon Cannister on 9th September 2017, 10:13 am
Daveymeladdy
Daveymeladdy
Some may consider this a silly question, but what the hell does the carbon canister actually do?
2 Re: Carbon Cannister on 9th September 2017, 10:41 am
Sure it's to do with emissions and the fuel tank vents to it. A lot of people remove them as age they are some won't work as should
3 Re: Carbon Cannister on 9th September 2017, 12:27 pm
After 1990 you can't vent your tank in to atmosphere (emissions and stuff). So basically all vapour is sucked through carbon canister which from what I remember removes any moisture in to your intake mani. I has got diaphragm controlled valve there which closes when you're boosting. Sometimes on R it causes bad idle and hesitation when gone. Remove throw it away and just blank off those two hoses which are going to manifold. I actually use one for boost gauge other for ebc.
