Gtir Motorsport club » General Discusion » Gtir related Discussion » Rear Caliper removal and braided lines
1Rear Caliper removal and braided lines Empty Rear Caliper removal and braided lines on 21st September 2017, 12:45 pm
boyciegtir325
OK I have done the right thing and searched in the search bar for anything related to this but can't find anything.
Can someone please tell me how do I take the handbrake cable off the caliper, do I just pull the spring in and slide the cable off or do I have to undo some bolts ?
Also with braided lines, what's the best way to stop the brake oil pissing out everywhere if the caliper will be off for about a week ?
Probably gonna send calipers to Biggred for refurb and paint job or may tackle meself !
Thanks in advance.
2Rear Caliper removal and braided lines Empty Re: Rear Caliper removal and braided lines on 21st September 2017, 1:09 pm
when I replaced one of my rear calipers recently I undid the bolt that holds the cable guide/support in place and then unhooked the end off of the pawl. dunno if that's the preferred method but it was easy to do it this way Smile
3Rear Caliper removal and braided lines Empty Re: Rear Caliper removal and braided lines on 21st September 2017, 1:11 pm
boyciegtir325
yeah just watching youtube and this is what someone else has done - thx
4Rear Caliper removal and braided lines Empty Re: Rear Caliper removal and braided lines on 21st September 2017, 5:59 pm
ADSgtir
You have to remove the caliper first , as the angle of the cable makes it harder to just unhook , caliper off and its easy to move around
use a small plastic bottle -pipe in bottle and tape it in place- when refitting new caliper , fill the reservoir with fresh fluid and allow it to gravity fill the rear lines - fill the caliper before fitting and this keeps bleeding to a minimum
5Rear Caliper removal and braided lines Empty Re: Rear Caliper removal and braided lines on 21st September 2017, 7:43 pm
Gtirchris
Being as you can't use a hose clamp on a braided line you need to open the bleed nipple, depress the pedal to the floor and use something to hold it fully down, this will stop it from loosing all of its fluid mate.
6Rear Caliper removal and braided lines Empty Re: Rear Caliper removal and braided lines on 21st September 2017, 9:10 pm
@mike74 wrote:when I replaced one of my rear calipers recently I undid the bolt that holds the cable guide/support in place and then unhooked the end off of the pawl. dunno if that's the preferred method but it was easy to do it this way  Smile
Thats what I did aswell.
7Rear Caliper removal and braided lines Empty Re: Rear Caliper removal and braided lines on 21st September 2017, 10:10 pm
boyciegtir325
briliant, thx guys, calipers off tomorrow with any luck !
