Gtir Motorsport club » Tech room » Help and Advice » oil feed to turbo
oil feed to turbo
1 oil feed to turbo on 24th September 2017, 11:15 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
can some one tell me which of the pipes from the block is oil feed. in fact can i just run through them all. so there are 2 pipes from the block that are next to dipstick. just want to know which one is which.
 photo 20170923_112509_zps1evzkokn.jpg" alt="" />
so in that pic u can see 2 bolts with pipes to turbo. located next to dipstick. can someone tell me which one oil feed.
thankyou
2 Re: oil feed to turbo on 24th September 2017, 11:16 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
[img][/img]
3 Re: oil feed to turbo on 24th September 2017, 11:18 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
so photos arnt working through photobucket. i did see the thread but forgot. pooh. im a noob on this stuff what do i use now to upload
4 Re: oil feed to turbo on 24th September 2017, 11:33 am
Try this mate https://imgbb.com/ It was working for me last time
5 Re: oil feed to turbo on 24th September 2017, 11:41 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
6 Re: oil feed to turbo on 24th September 2017, 11:47 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
20170923_112452
7 Re: oil feed to turbo on 24th September 2017, 11:49 am
Bottom one is for oil (smaller banjo) top one is for coolant
8 Re: oil feed to turbo on 24th September 2017, 11:59 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
ok thanks. thats great.
so the one that is the silicone hose at the bottom of turbo. going into lower part of the block i assume is oil return??
9 Re: oil feed to turbo on 24th September 2017, 12:16 pm
10 Re: oil feed to turbo on 24th September 2017, 12:22 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Thanks B. thats great.
11 Re: oil feed to turbo on 24th September 2017, 12:42 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
my turbo has been off the car for some months and will be dry of oil. should i try to get some oil into feed tube now. before i start engine. or will there be immediate oil pumped in as soon as i turn the key. just abit worried about burning it out.
12 Re: oil feed to turbo on 24th September 2017, 7:22 pm
Just disconnect injector balast and crank it till oil light will go out (car won't start) and then just plug it back in
13 Re: oil feed to turbo on 24th September 2017, 9:00 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
ok got it. thanks mate
14 Re: oil feed to turbo on 24th September 2017, 9:37 pm
How long has it been sat?
Might be worth pulling plugs out first and cranking over with plugs out .
15 Re: oil feed to turbo on 24th September 2017, 9:44 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
around 6 months. had a rebuilt engine put in. which i have been hand cranking every few week. yes i will defo crank over with plugs out. just didnt know that would fire the oil round to turbo. cheers.
