Gtir Motorsport club » Gallery » Projects » Another restoration thread.
Go to page : 1, 2, 3, 4, 5, 6  Next
Go down  Message [Page 1 of 6]
1Another restoration thread. Empty Another restoration thread. on 7th October 2017, 8:21 pm
typeritr
typeritr
So in January I bought a Pulsar GTI-R. From the moment I test drove it I knew i had to have one. I thought I found a rare good car in that it only had rusty arches and just rebuilt engine with new clutch and all. I got the arches fixed and had started to tidy it up etc... while buying parts for it I came across another pulsar, it had not run in a few years and was parked up in a garage. I checked it out and there was no rusty arches and it seemed in good nick overall. So I went to buy a few plastic bits and bought a whole new car, a "project" car. So the car itself is a 1994 with 80,000km on the clock and was always garaged.
I plan to do a very extensive rebuild of this car, including zinc plating the nuts and bolts, underdsealing everything, waxoiling everything, replacing any scratched or broken parts, fitting a few nice OEM extras and changing all the phase 2 parts back to phase 1. This rebuild will end in a full respray, properly done including inside the engine bay etc... no part of the car will be left unsprayed. The colour I intend on using is AMG matt Grey Metallic. Expensive paint but worth it.
Anyway, the first problem I came across was finding a place to store the car while I worked on it, lucky I found a garage less than a 10 min drive away willing to have my car there while I work on it. For a fee of course. Got it delivered down last week and started to work on it this week.
My plan of action is not hugely defined but I have a general idea. Bearing in mind I have never undertaken any task like this ever before. So be prepared for me posting a lot of questions on the forum in the near future!!! (inevitably when I forget what parts are what, or how they go back on)
I am going to work from back to front. I have already started to strip the car down.
Here is the car before i started. Just had the side skirts taken off
Another restoration thread. 23668628348_1aa988c5e7_z
Another restoration thread. 36810516194_e1a6ba8ff9_z
Another restoration thread. 23668626988_26e5468eea_z
Hub Removed
Another restoration thread. 23668625538_cc4aa7882f_z
Coilovers removed. Was happy to see the level of rust was not too bad here even before i have done any work on it. You can see the arches are in good shape. The petrol filler hose on the other hand needs to be replaced.
Another restoration thread. 23668628858_0f49093077_z
Next inline was to remove the subframe but took a few other bits off too.
Rear Diff and propshaft off. You can see I bent a part on the top of the diff so need to find a replacement for that. Also I saw recently someone replaced the seal on the diff, is the seal a weak point that I should replace? I also want to replace all the knuckles, bearings and rubbers on the propshaft. So if anybody knows part numbers, or where all these bits can be found it would be much appreciated.
Another restoration thread. 36886590803_54681e4fd6_z
Another restoration thread. 36845977574_5b20afbf04_z
Another restoration thread. 37508404066_cbefa54300_z
Another restoration thread. 37298007540_2df6e6f42a_z
Petrol tank off. Again I am going to replace everything on this, new rubber hoses, pump and filters. Before and after a power hose.
Another restoration thread. 37297918900_a03aa7f35c_z
Another restoration thread. 36886765313_0ff6be2783_z
There is a rattle inside it, i never opened it but i reckon it could the level sensor broken so may need to buy a whole new mechanism!
Will get the heat shields galvanised, also have the turbo heat shield and cat heat shield.
Another restoration thread. 37556145341_0a89b9a9f4_z
Subframe down:
Another restoration thread. 23668630098_7b4cb503e3_z
Another restoration thread. 23668627538_29798ef7b1_z
A picture where you can see a bit more of the underside of the car.
Another restoration thread. 23668623578_5a85d456e9_z
Everything removed. I am surprised at the condition of everything really. I mean apart from flaking paint and just looking grubby in general everything is in very good condition. The coil overs are in very good condition if a bit grubby. I am thinking i will just clean them up as i was considering a set of meister R.
Another restoration thread. 23668624508_6635022984_z
I stripped the boot of all its plastics and the rear seats. Which is very easy. Bolts and clips and everything comes apart. I did it carefully to not scratch, damage or lose any of the interior plastic bits.
I have to say i was very happy with what i saw. This is what i came across when I removed the interior side panels. Very clean and dry with virtually zero rust. very rare indeed.
Drivers side
Another restoration thread. 23668629518_2e0bd9cddb_z
Another restoration thread. 23668621638_cc5006e150_z
Another restoration thread. 36810516624_8b9b4778e2_z
Another restoration thread. 23668627998_ac38efff33_z
Passenger side
Another restoration thread. 23668626038_ab2ff9838b_z
Another restoration thread. 23668625158_de90669ece_z
Another restoration thread. 36810515124_4c299ba22d_z
Another restoration thread. 37489739852_37b5f6000d_z
You can see a tiny line of rust starting to form along the seam of the rear arch. Luckily though it is only starting and I got it in time. I plan to get a soda blaster in and blast that away then hover out all the debris. I will degrease everywhere inside the arches and absolutely cover everywhere inside there in Bilt Hamber Dynax waxoil. You can see I have not removed the bottom bolt of the rear seat belts. Looks like they are actually bolted through the bottom of the car?? so need to get a wrench underneath too. That is for another day though.
So far so good with regard the overall condition. I am going to try take more detailed pictures from here on in.
One thing to be sure of though is to lable all the bolts
Another restoration thread. 37490304302_c85c3446e2_z
Finally
Storing a few extra parts here. Seems to be a trait of GTI-R owners by the looks of it
Another restoration thread. 23704026748_3b3911d1e0_z
I know what everything in all the boxes are apart from these, can anybody name these parts for me? or where they go.
Another restoration thread. 37508028816_289399c916_b
This is going to take some time and will be a slow process but I will try keep this up to date as I go along.
I think this is going to turn into a very expensive project!
Will keep ye all updated." />
2Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 3:45 am
Great post mate, looking forward to watching the progress. Its a great starting point finding one in good condition and makes a solid foundation for what you are looking to do. Keep at it and it will be well worth it.
3Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 5:10 am
Pulsartim
Pulsartim
Hi great to hear another Pulsar is getting some tlc. It looks like you've got a better starting point than mine, I see your thinking of Zinc plating every nut and bolt like me......if you've not done it before I can give you a few tips as is a bit hit and miss till you get the hang of it.
4Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 7:33 am
Nice work, hopefully you can get it together and finished before the 30th Anniversary 2020...
5Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 7:37 am
This will be a great thread to watch, if love to do something like this! With regards to the picture with the random parts, from what I can see you have, 1. Carbon canister (top left of picture) 2. Top right of the picture is the spark plug or injector (resistor I think) 3. Oil/water separator (black rusty square box) 4.window wiper motor 5. The 2 large rusty lumps of metal are for the gearbox and transfer box, one bolts to the engine and to transfer box. 6, engine stabiliser 7.theres a bracket there that the engine stabiliser attaches to and believe to the transfer box.8. There’s a bracket that attaches to the underside of the car and to the shifter mechanism. 9. There’s a few other parts I recognise and know where they go, if you’re unsure post a picture up of each individual part and myself and I’m sure others will be happy to tell you what they are Smile hope that’s of help pal
6Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 2:50 pm
Where abouts are you based mate? Will this include engine, gearbox rebuild too?
Looking forward to watching how you get on. Very Happy
7Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 4:25 pm
Handbrake cable splitter is the part with the rubber there is a fuel pressure Reg in pile as pete says less items per photo will narrow them down.
Look forward to this thread. I guess you probably plan to keep the car years but never say never and colour sounds nice but should you ever need to sell And your leaving nothing unpainted would probably fetch top dollar standard colour. I know it means paying twice but it would protect the paint you could wrap it grey leaving bay and interior nice new black
8Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 7:12 pm
typeritr
typeritr
Thanks for the comments lads. I realised after I posted the picture of all the parts that I should have numbered them or something!! Another thing I noticed was filtering for used pulsar parts on ebay is very helpful for identifying what they are as there are quite a few of the bits I pictured for sale.
I might take you up on that offer PulsarTim. I wont be starting to do the bolts for abput 3 weeks as i am on holidays for a while but once i get the kit i may drop you a pm.
I am in Ireland Cosmic. It does include a full forged engine rebuild, but I would not have the skills to remove and rebuild the engine myself, I am only chancing my arm doing as much as I plan on doing as it is.  so again that will happen early in the new year when I get more cash together. When the gearbox blows then that will be rebuilt.
I appreciate what you are saying about the colour, I do appreciate originality too, however I am not making it to resell. If i was going for originality I would not be putting the phase 1 pats on either. I plan on keeping it so just want my favourite car colour on it. I have had my Honda Integra for 10 years already with no plan to sell that, this pulsar will be the same.
9Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 7:23 pm
Daveymeladdy
Daveymeladdy
Good work mate. I can imagine this is the bad bit, putting it back together again will give you real satisfaction
10Another restoration thread. Empty Re: Another restoration thread. on 8th October 2017, 7:48 pm
Nice to hear your in it for the long term. It's your car I seen them in Mat grey they look nice was just putting it out ther incase you spent all that money and time and it did not cross your mind . Any pictures of the teg ?
11Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 9:09 pm
typeritr
typeritr
Here are pictures of my Integra
Another restoration thread. 36891658424_bbcc12e020_z
Another restoration thread. 37570016632_04cb944970_z
Another restoration thread. 36891657054_160e538473_z
I reckon putting it back together will be a lot harder than taking it apart!
So I did a bit more stripping the interior before i go away for 2 weeks. Reason being the dash was split so going to replace it.
Another restoration thread. 37343205470_85c4656751_z
Another restoration thread. 36931515293_ffe114cb7a_z
Also took the seats out and found this.
Another restoration thread. 37343207020_dac12eb767_z
Another restoration thread. 36931514523_7094447741_z
Another restoration thread. 36931514963_2acd8e7403_z
Another restoration thread. 37343206080_638daa0b78_z
I really should be shocked to believe that somebody is willing to drive with a seat like this. But I have come to realise there are a lot of stupid people out there, with absolutely zero regard for their own safety or the safety of their passengers, I would be embarrassed to leave this seat in my car.
I have taken over 2 rooms in the house now at this stage.
Another restoration thread. 36931513473_6b8ee300d1_z" />" />
12Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 9:19 pm
Good to see another R being restored. I'm currently doing mine, thought it would be done by now but she will be worth it once completed. Good luck with everything.
13Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 9:20 pm
Those wheels really suit the Integra, looks good.
What did they try and do to the rails?
14Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 9:55 pm
typeritr
typeritr
Yeah there seems to be a few of these car mid restoration at the moment, good looking through all the threads about them too though. How long have you been doing yours? I am hoping to have my car done by march, as i have every evening free until march so literately Monday to Thursday I will be working on the car every night after work. The engine rebuild will be last to be done, funded by selling my other GTI-R, so until that one is sold this one will keep a standard engine in it.
Thanks, they were expensive wheels but worth it!!
The mounting points of the seats look as though they were cut off and just tack welded back on badly, the previous owner must have thought that would do the job in a crash.
15Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 9:58 pm
Looks like they've possibly tried to lower the rails so the seat sits lower in the car ..
I may however be very wrong
16Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 10:01 pm
typeritr
typeritr
How does one remove the rear seat belt mounts? The bolt keeps spinning for me and not coming out.
17Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 10:03 pm
Started mine two years ago but had to move units early on. I might have it done for next summer but I'm in no rush. I try and get to it after work every now and then but normally only get a Saturday or Sunday to work on it.
18Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 10:04 pm
They should be into a captive nut .
I suspect you'll need to get the grinder out
19Another restoration thread. Empty Re: Another restoration thread. on 9th October 2017, 10:04 pm
I can't imagine any other reason they would need to be mucked with rob. Unless changing how far back/forward the seat moves.
20Another restoration thread. Empty Re: Another restoration thread. on 18th October 2017, 9:37 am
Ryaneg6freak
Ryaneg6freak
I am way jealous mate, I wish my inside panels where they meet the inner arches looked like that. Mine are horribly rusted and I had to cut out nearly have of my inner turrets and fabricate new panels.
21Another restoration thread. Empty Re: Another restoration thread. on 25th October 2017, 7:22 pm
typeritr
typeritr
Yeah i think i got lucky with this Pulsar rust wise. Not just the inner turrets, the long hub bolt came out very easily too which could be down to lack of corrosion.
I was on holidays the last 2 weeks so didnt have a chance to work on the car, didnt stop me buying things though!!!
So since the sub frame was off, I had a spare subframe powder coated and pollybushed along with all the suspension links. Got a whiteline antiroll bar and some superpro drop links
Another restoration thread. 37899640192_632d758f62_z
A few bits needed for the phase 1 conversion.
Another restoration thread. 37899642212_271b0083bc_z
Couple of Extras
Another restoration thread. 37930637731_bcd245ec95_z
Another restoration thread. 37930638171_f604d0b42a_z
Another restoration thread. 37899637392_6640194377_z
HKS boost controller there. The Brembos are from a Peugeot 406, I thought they were going to be an easy fit, but apparently the guy who made the brackets said they were a bit tricky, I have clio discs for them and H&R 15mm spacers
The boot of the car was empty so got these together.
Another restoration thread. 37930636161_80e9a3ddde_z
Got a rear caliper rebuild kit from Big Red
Another restoration thread. 37930639241_412a7d6257_z
So in order to actually restore the car I needed a sand blaster. Queue Aldi with their great timing. Air compressor ans spray guns!! Everything needed to blast the rust away and spray the underseal.
Another restoration thread. 37930637401_b5fe978932_z
Another restoration thread. 37930636821_2b4fe55916_z
Finally my Zinc Plating Kit!!
Another restoration thread. 37899640892_3ca0530dd9_z
Looks like something out of braking bad!
On order is the soda blasting media and a brembo rebuild kit. Once they arrive time to get to work again!
Once I get working on the car again I will take some progress pictures of the work, not just pictures of parts and equipment!
22Another restoration thread. Empty Re: Another restoration thread. on 25th October 2017, 8:06 pm
You have a nice collection of parts now Smile
23Another restoration thread. Empty Re: Another restoration thread. on 26th October 2017, 9:04 pm
typeritr
typeritr
@gtir_woody wrote:You have a nice collection of parts now Smile
Yeah have quite a few bits now.
I went about stripping the rear brakes today and cleaning the bolts. Monday I'm going to clean the calipers up and fit new seals and pistions.
I used vinegar to try dissolve the rust. It seemed to do the trick quite well. It didn't get everything off. Once i took them out of the vinegar i dropped them into some Baking soda and water to neutralise the acid.  Not sure I can zinc plate them unless they are spotless? anybody know? If that is the case, I will sand blast them on Monday while I am doing the rear calipers.
Another restoration thread. 37951702021_bf8dfdab84_z
Another restoration thread. 37921138642_de82bdcec1_z
Another restoration thread. 37951704651_4f47967fe2_z
Another restoration thread. 37951703601_a3a09d6892_z
Another restoration thread. 37921138932_9e4dc26244_z
Another restoration thread. 37951707011_1a7a09fdb0_z
Another restoration thread. 37921135692_df3e723687_z
Another restoration thread. 37921138102_48c3631bba_z
The Subframe cups didn't really get better at all. Also I spun the camber bolts on the rear subframe, the washer with the notch, looks like i destroyed the thread on the bolt so think i will need to source one of them.
On a side note, if anybody wants OEM alloys, tein coilovers or a set of wind deflectors let me know. The Brembos wont fit under the OEM alloys
24Another restoration thread. Empty Re: Another restoration thread. on 26th October 2017, 10:51 pm
One of my customers swears by this stuff for cleaning up rusty bits. Wanna try it myself but my company will only buy it in bulk.
http://debskincare.co.uk/janitol-altrans-5-litre.html
25Another restoration thread. Empty Re: Another restoration thread. on 27th October 2017, 4:26 am
Pulsartim
Pulsartim
Hiya great work mate it looks like were carrying out our rebuilds at the same rate.
if your plating I've found removing the rust from the smaller items i.e. nuts and bolts in vinegar does the trick,  when it comes to plating it depends what finish your after. if you want a bright finish, once you've neutralised the vinegar polish on a bench grinder wire wheel, the brighter you get the part to be plated the brighter the finished item once is passivated.  if your plating for rust protection an painting after then blasting will come up with a good enough result for the item to be plated.    You have to remember when plating at first its all down to trial and error.....you'll get a lot of failiures to start with till you get the nack and then the failure rate will drop off.
Back to top  Message [Page 1 of 6]
