Gtir Motorsport club » Gallery » Projects » Another restoration thread.
Go down  Message [Page 2 of 6]
26Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 27th October 2017, 3:02 pm
typeritr
typeritr
Thanks for the advice.
I am going to blast them. I don't need a polished shiney gold finish. As long as they are zinc coated and good enough to hold up to the elements I will be happy enough.
I don't think I will need to do the Vinegar Dip going forward though, if they will need to be blasted anyway. Using soda blast as to not damage the threads.
I have not even read the instructions yet for the plating kit, will leave that until next week when i start that process. May plate the calipers too when they are blasted.
I can imaging it will be trial and error as it does not sound like the most straightforward thing to do.
27Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 27th October 2017, 10:10 pm
If you want to be picky, those sub frame cups are still available from nissan and really cheap.
28Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 28th October 2017, 6:15 pm
You got a part no woody
29Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 29th October 2017, 7:00 am
5547535F00 Smile
30Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 29th October 2017, 7:08 am
Nice one thanks
31Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 29th October 2017, 10:32 am
typeritr
typeritr
Might have to use that part number too. Thanks woody.
I will be making an order soon enough from Nissan.
Hopefully they still supply the hard lines for the brakes and fuel.
32Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 29th October 2017, 5:57 pm
Ryaneg6freak
Ryaneg6freak
@typeritr wrote:Might have to use that part number too. Thanks woody.
They don't, but it's easy enough to make your own. And for brake lines, I'd probably just buy one of those nice pre-fabricated and terminated kits that are made of braided stainless. They're really nice quality.
https://www.ebay.co.uk/itm/Nissan-Pulsar-Gti-R-ABS-Delete-Kit-Braided-Brake-Lines-Hoses-Nismo-Gtr-Gtir/282564669676?hash=item41ca2ab0ec:g:~iAAAOSwstJZSYYZ
33Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 29th October 2017, 6:50 pm
typeritr
typeritr
That kit looks very nice.
I will send them an email and see if thay can make them for an abs car.
From reading the description it seems they supply everything except the last line. That goes from the inner arch to the actual calliper.
I already have them braided lines so this seems exactly what I am looking for. Thanks for the link
34Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 29th October 2017, 7:23 pm
Let us know what they say mate
35Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 30th October 2017, 7:01 am
Ryaneg6freak
Ryaneg6freak
@typeritr wrote:That kit looks very nice.
I don't believe they do, the whole point is to remove the ABS system (which on a pulsar isn't a bad thing, the ABS is terrible and it frees up alot of space), and no, they don't supply the lines for the calipers, those are separate, but also easily available.
I have the full delete internal kit with the Wilwood bias knob inside the car, it's a very nice kit and well made, and the lengths are perfect.
I forgot to mention you can get the outer sheathing in just about any color you can imagine, I went with black so they don't stick out too much, but you can get neon green if you wanted it.
36Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 1st November 2017, 10:28 pm
typeritr
typeritr
So I asked them about the ABS and they supply it. I ordered a set in the carbon look sleeve and got a braided clutch line thrown in too while i was at it. I already have the Goodridge carbon look lines that go to the calipers.
It seems all i am doing is buying parts at the moment.
Another restoration thread. - Page 2 38098573581_3a53ba39ff_z
Another restoration thread. - Page 2 38098574731_6587ae2b0d_z
Another restoration thread. - Page 2 38098574201_b5cf9e3504_z
Another restoration thread. - Page 2 38098571841_ecc8b69652_z
Greddy Manifold, not too happy with the flange on it though. I am looking to buy a Holset turbo, but they are all twin scroll manifolds, the OEM manifold actually looks better suited to the twinscroll than this manifold. The exhaust pipe that feeds the turbo seems to be a small enough diameter. Anybody got any experience of the Greddy Manifold? This one was ceramic coated at some stage.
Another restoration thread. - Page 2 26322234679_8b6124c2b4_z
Another restoration thread. - Page 2 26322232549_067f3f2ff2_z
Brembo rebuild Kit. Once I get the lines delivered i am going to have more or less a brand new breaking system fitted.
Also front ball joints and poweflex front wishbone bushings (I forgot to order track rod ends when ordering these ball joints) might not seem like much, but when in Ireland people like to charge £10 and £15 to post small items, so it is always a very bad idea to not order things together!! Also going to get the Engine mount and gearbox mount bushings. Then will have a complete powerflex bushing kit.
Tomorrow I am removing the front hub, drive shafts, old calipers, track rod ends, coilovers, wishbones and anti roll bar
37Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 1st November 2017, 11:00 pm
Keeping yourself busy .... keep up the good effort fella ....
38Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 2nd November 2017, 11:18 pm
typeritr
typeritr
Some more updates today.
As i said I was going to do yesterday I removed the front hubs, drive shafts, old calipers, coilovers, wishbones and anti roll bar. I didn't get the passenger side drive shaft off, or the track rod ends off.
Another restoration thread. - Page 2 37414699044_47009976b1_z
Hubs came off easy enough, so did all the ball joints and the coilovers. I didn't take off the track rod ends as they look severely rusted on to the steering rack, also the boots on the steering rack are all split. Have to consider what to do from here. I think i have a spare steering rack so will see what condition it is in.
The arches, front sills and behind the arches (much like the rear of the car) are in decent condition. The hole cut for the intercooler piping is not the best, will need to tidy that up, maybe find a big rubber grommet for it
Drivers side:
Another restoration thread. - Page 2 38092252852_a3cdcebddb_z
Another restoration thread. - Page 2 37414714694_ebe829923b_z
Another restoration thread. - Page 2 37414702564_44f22f8493_z
Another restoration thread. - Page 2 37414706254_12dff09c6f_z
Another restoration thread. - Page 2 26347287049_2ea76c9ea1_z
Passenger side:
Another restoration thread. - Page 2 37414717894_011f7507a3_z
Another restoration thread. - Page 2 26347282589_9dfc53b08d_z
Another restoration thread. - Page 2 37414719094_b74132de77_z
Another restoration thread. - Page 2 26347286049_95f38e5687_z
Another restoration thread. - Page 2 38069509706_cc9abe9019_z
Rear of the car looks OK too
Another restoration thread. - Page 2 38092255242_2c8847d702_z
Another restoration thread. - Page 2 26347284179_bb83235550_z
Another restoration thread. - Page 2 38069507146_ff0f0c00aa_z
Another restoration thread. - Page 2 38069506416_3a8a3035e0_z
Another restoration thread. - Page 2 37414712264_eeae363403_z
To be honest the back of the car was a lot nicer to me, I as have found a few more problems with the front of the car.
A crack in the gearbox housing!
Another restoration thread. - Page 2 38069507946_54078e2ff5_z
A lot of sealant on the gearbox case and on the oil pan!! I cant think of any good reason why they would be like that!!
Another restoration thread. - Page 2 37414701284_7fc01468f8_z
Another restoration thread. - Page 2 37414721404_5df5af6f98_z
On top of that, both boots on the steering rack broken, the rusted track rod ends, the drivers side driveshaft has a broken boot and a lot of in out movement.
I couldn't remove the drivers side drive shaft as i was not sure if it needs to be unbolted?? Can any one tell me?
Another restoration thread. - Page 2 37414709244_29cc8879e4_z
The front wishbones are not the best either!! A lot worse than the rear subframe was
Another restoration thread. - Page 2 37414711564_eab05bee64_z
Can the rubbers at the end of the wishbones be replaced? The bigger ones, they are at the end on the right in the picture? If they cant I may just get a full replacement wishbone, rather than refurbing these ones.
Was surprised to see a Nissan oil filter
Another restoration thread. - Page 2 37414697604_6634070ec2_z
I now know what make of Tein coliovers are on it.
Another restoration thread. - Page 2 37414696534_8ccdedff35_n
Finally just 3 pictures of how it look overall at the moment
Another restoration thread. - Page 2 37414709884_d4ae60cb05_z
Another restoration thread. - Page 2 37414710744_ffcf5f383a_z
Another restoration thread. - Page 2 37414712954_63d0a5b94a_z
Over the weekend I am going to sand blast all the parts I have removed and get them coated
39Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 3rd November 2017, 6:59 am
Keep up the good work
Shaft dose not require un bolting
There will be other places do it
https://m.ebay.com.au/itm/MRC-Whiteline-KCA346-Adjustable-control-arm-bush-anti-lift-GTiR-N14-N13-EXA-KN13-/272010757165
40Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 3rd November 2017, 9:59 am
typeritr
typeritr
Thanks for the link, I also found these.
https://www.superflex.co.uk/proddetail.php?prod=SF280-1374AK
They are nearly half the price of the Whiteline, but don't have the added washer that moves the wishbone down lower to the ground. I think I can forfeit that though, I am sure it does improve it somehow but I don't know.
The more you strip the car the more parts you find you need to buy! I thought I had all my purchasing nearly done.
41Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 3rd November 2017, 10:08 am
this guy does a lot of GTIR stuff too, at a fraction of the cost of the 'usual' bush suppliers. I've got his steering rack bushes on my car just now and they seem alright  Smile
http://stores.ebay.co.uk/polytorq?_dmd=1&_nkw=GTIR
42Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 3rd November 2017, 3:47 pm
Ryaneg6freak
Ryaneg6freak
Looking good and if should ever decide to sell that turbo manifold, I want first dibs! i haven't seen one of those in years!
43Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 3rd November 2017, 9:19 pm
astarozna
astarozna
What Holset you are thinking about, Hx35 super perhaps?
new ~ £ 670 - £700 and about £400 slightly used
44Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 3rd November 2017, 11:11 pm
typeritr
typeritr
That last link for the bushings, they may be the Ones I go for, very good prices!!
I will see about the Greddy manifold, if it works well I will be keeping it.
I was gonna get a holset HX32 but it sold, next time one comes up for sale I am going to buy it straight away. They are good for 400 to 500 bhp and supposedly spoil before 3.5k in a 2 litre
45Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 8th November 2017, 8:30 pm
typeritr
typeritr
Another update.
Still not done much work on the actual car. As there is very little rust I reckon work on the car wont actually take that long, I have it stripped already, just need to spend a few days wire burshing to get the shell totally clean and then underseal it a few times.
Wire brushed the hubs and painted them.
Another restoration thread. - Page 2 37560077774_7ba9f51d4e_z
Another restoration thread. - Page 2 37560081974_879d23d626_z
Another restoration thread. - Page 2 24399901878_a0ac909ff7_z
Started to dismantle my Brembo brakes, 2 pistons had broken seals, so needed to sand both the piston and the hole the pistons went into.
Another restoration thread. - Page 2 24399902068_3c2f695d50_z
Another restoration thread. - Page 2 37560078254_cfc3f9fb9f_z
Another restoration thread. - Page 2 37560075324_4f541e2e17_z
Another restoration thread. - Page 2 24399902658_a979bb6d2e_z
So I planned on getting a Holset turbo, however, when you end up getting a relatively good deal elsewhere sometimes you divert from the plan. Ended up getting a brand new unused Garrett turbo with Apex braided lines and a brand new unused HKS actuator. I had already bought a Turbosmart external wasgete though for the Greddy manifold so am a bit overstocked now. Think I will use the Turbosmart wastegete on my integra to get rid of some boost in first and second gear as I get a lot of wheel spin.
Another restoration thread. - Page 2 37560078744_274c3192f7_z
Another restoration thread. - Page 2 37560072564_18d5aaf881_z
Another restoration thread. - Page 2 26494578209_93d96bcd9c_z
Another restoration thread. - Page 2 24399900468_ca105f60c3_z
Another restoration thread. - Page 2 37560081194_4f9a4da5b7_z
Another restoration thread. - Page 2 37560073494_77b08b8e11_z
Another restoration thread. - Page 2 37560080004_47418dea9e_z
Another restoration thread. - Page 2 37560074244_d30b84e869_z
Tomorrow I am going to fit some security to the car and also remove the Hard fuel lines and replace them for some braided lines. Right now though I have to stop buying bits, I have drained my GTI-R account very quickly, I can afford one more purchase then I'm out.
I have some things to sell to fund the rest of the project. I have to sell my other GTI-R, Tein coilovers, OEM wheels, white dials, wind deflectors, 1 set of 18" Rays CE28n, 2 sets of 17" Rays TE37s, 1 set of 17" Rays SE37 and a Silvia megan racing manifold. Once i sell all them bits I will be back on the road with this pulsar.
46Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 8th November 2017, 10:07 pm
I'd be interested in the Te37's you may be selling
47Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 8th November 2017, 11:00 pm
typeritr
typeritr
Sent you a message there Rob. At least you know the funds will be going to a good cause!!
48Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 10th November 2017, 7:29 am
Ryaneg6freak
Ryaneg6freak
@typeritr wrote:That last link for the bushings, they may be the Ones I go for, very good prices!!
Doesn't the Greddy manifold have a triangular flange for a Greddy TD-05?
49Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 10th November 2017, 8:26 am
nice, hopefully selling those parts covers the cost to finish this off. Funds go quickly when modding.
50Another restoration thread. - Page 2 Empty Re: Another restoration thread. on 10th November 2017, 8:56 am
typeritr
typeritr
THe Greddy manifold does indeed have a triangular flange. I am going to weld a T3 flange onto it though to fit the new turbo.
They will sell alright, when is the problem!! I want them sold yesterday already, nothing worst than getting stuck half way through!!
Back to top  Message [Page 2 of 6]
