Gtir Motorsport club » Tech room » Gearbox section » clutch master cylindar
1clutch master cylindar Empty clutch master cylindar on 3rd November 2017, 7:38 pm
Zia
My clutch pedal has starting to feel odd.had a look at clutch master cylindar and i can see grease and fluid leaking.looks like i need new master cylindar.stumbled upon this on ebay anyone used these to rebuild master cylindar?
http://www.ebay.ie/itm/282639540551?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Zia
2clutch master cylindar Empty Re: clutch master cylindar on 3rd November 2017, 8:27 pm
Should be fine since OEM.
Same people selling that kit (ICP) do a complete cylinder for £30 (check what make it is as they sell quite a lot of chinesium shit these days)
https://www.importcarparts.co.uk/parts-info?id=1618&cat=0&sub=0&sec=0&var=0&dc=&gen=&searchKey=&searchPart=
I used seal kit like below couple times no problem .
https://www.ebay.ie/itm/Brake-Caliper-Repair-Kit-AUTOFREN-SEINSA-D1390-for-Nissan/332161776156?hash=item4d56627a1c:g:y74AAOSwYXVY0iLk
Other good option is Blueprint cylinder ADN13439
Other thread on clutch master and slaves
http://www.gtir-motorsport-club.com/t6999-clutch-master-cylinder-slave-cylinder-service-parts
3clutch master cylindar Empty Re: clutch master cylindar on 4th November 2017, 7:24 am
Defs go with options people have used before. I had drama's buying an ebay one before.
4clutch master cylindar Empty Re: clutch master cylindar on 4th November 2017, 2:04 pm
^ Yeh I remember that Woody. I used the Blueprint and TRW full cylinders no issues, blueprint master and slave .
I used frenkit autofren master seal kit and all worked fine besides outer rod bellow boot needed retain original .
£25 for oem repair kit and less potential ballache not a bad thing if available easily and happy with cost .
I liked the full blueprint cylinders but harder get these days at sensible money .
5clutch master cylindar Empty Re: clutch master cylindar on 4th November 2017, 5:54 pm
Zia
My local nissan dealer wants £110 +vat.. lol i bought one a good few years ago and they were only £75.
Managed to get old one out.
clutch master cylindar 26390893029_a1ed0caa72_h20171104_141840 by
zia
6clutch master cylindar Empty Re: clutch master cylindar on 4th November 2017, 6:48 pm
Use to get the ADN13439 for low £40. they more like 70 to £80 now ...
ABS brand master about £30
Woody had Japanparts master and slave and he had issues unfortunately .
Doing seals on clutch masters is really easy so not a bad way go for £10 after market or £25 oem
OEM kit is more complete parts not just seals .
7clutch master cylindar Empty Re: clutch master cylindar on 4th November 2017, 8:18 pm
Zia
Nissan part kit is 306112T025 i think? can get one in 9,10 days so may just get that.
zia
8clutch master cylindar Empty Re: clutch master cylindar on 4th November 2017, 9:34 pm
kit is 3061102Y25 or 3061152F25
Fits lot of models so easy get and if you known to your nissan parts team likely less than £20
9clutch master cylindar Empty Re: clutch master cylindar on 5th November 2017, 7:22 am
As Mr B said, I went OEM nissan and had no problems but certainly alot more expensive when other options as described are available.
